Breather filter w/s480
Old Sep 13, 2014 | 12:43 AM
AkSSS's Avatar
Default Breather filter w/s480
I am getting close to firing up my new setup and I am trying to narrow down a few details. Bare with me, I am using my phone to post this.
I have a s480 going on my 408 and I am using a new set of kbracing hot pipes. My old setup was running a MP t-76 with kyles old pipes and my breather fit great. So fast forward to now and the breather doesn't exactly fit well.
I am changing my catch can setup from a non vented to a vented setup with a #8 line from each valve cover to the vented can with a line from the turbo to the can also. So my question is, is there a direct bolt on filtered breather that will clear the turbo? I haven't even put my blanket on to my turbo and it is already touching. I have considered forcing everything together and hoping that my blanket will keep the turbo from melting the full tube but I don't know. My breather I have now is a Casper breather on a TBSS filler tube.
Any ideas please let me know.
Old Sep 13, 2014 | 01:02 AM
idahoblkss's Avatar
not sure if it would work because ive never tried it but what about switching valve cover sides and putting the vent on driverside ?
Old Sep 13, 2014 | 01:22 AM
AkSSS's Avatar
That might work. I would probably just have to get a short filler neck. That is definitely an option. Then I could just drill out and tap the old Pcv port to a 1/2" pipe since I have a 1/2 pipe to 8an adapter and run that line from the moved passenger side. Doable!
Old Sep 13, 2014 | 09:25 AM
Razor's Avatar
BMF
Screw one of these into your valve cover and run the -8an line to your catch can. I have one on my car in -10an...works fine.
Old Sep 13, 2014 | 09:32 AM
smokeshow's Avatar
Mod with training wheels
^^ That's what I use.
Old Sep 13, 2014 | 12:33 PM
AkSSS's Avatar
Don't you need to have a breather on the motor for fresh air? That fitting would make it really easy to put the an lines to the catch can for sure. But then do I need to get fresh air into the crankcase?
Edit-do you think a #10 is needed? Or an 8 is ok?
Old Sep 13, 2014 | 01:23 PM
GMCtrk's Avatar
Its not about getting air into the crankcase. Its about getting gas from the crankcase out. Boost increases blowby.
Old Sep 13, 2014 | 02:28 PM
AkSSS's Avatar
I understand that you do not want any pressure in the crate case. I guess in actuality you would want to have a vacuum on the crank case at all times. That would make it easier on the rotating assembly correct? Why did I even bother running a breather on my old set up? I thought you still needed a way to get fresh air into the crankcase. If not then perfect. I will just run both valve covers to the catch can.
Old Sep 14, 2014 | 04:04 PM
AkSSS's Avatar
Are you running a filter also or just the lines to the catch can? And are they 10an or 8an?
Old Sep 14, 2014 | 04:08 PM
smokeshow's Avatar
Just a filter.
