Brake Boosting My Truck Video - Help
Old Aug 30, 2012 | 08:00 AM
Choda's Avatar
Thumbs up Brake Boosting My Truck Video - Help
I was WOT in 1st gear and 4wd. It wont rev past 2200 and kinda studders there which is only 5psi. Anything in particular causing this? What do you guys think.
Old Aug 30, 2012 | 08:14 AM
Johnmaster's Avatar
MASS seller approved
5 psi at 2200 isn't bad, you need a higher stall converter if you want to be able to slip it higher...
Old Aug 30, 2012 | 08:35 AM
nonnieselman's Avatar
IF it studders, it could be a lil lean.. wideband?
Old Aug 30, 2012 | 08:40 AM
You could have the problem i was having years ago...
Yank stall was a wee bit loose for me.. if i held it, it would go to 4800.
http://img.photobucket.com/albums/v4...Laptopshot.mp4
Old Aug 30, 2012 | 08:58 AM
Choda's Avatar
Yeah, the stock convertor is holding me back but i wanted to see 8 psi at launch to get sub 2 sec 60 foot
Old Aug 30, 2012 | 10:31 AM
9 Second Club
It looks like it's related to Brake Torque Management in your tune. I had a similar problem, and adjusted it in the tune, now I can make full boost off the brake.
Old Aug 30, 2012 | 10:55 AM
Choda's Avatar
man these PCs are crazy. What the hell is a brake torque management? and how does it effect the truck.
leaving at 8psi would def get me into the 13s at over 100
Old Aug 30, 2012 | 11:22 AM
man 5psi at 2200 is damn good!! what turbo do you have on there?
Old Aug 30, 2012 | 11:24 AM
Bama2door's Avatar
Haha i've never even heard of brake torque management...learn something new on here everyday
Old Aug 30, 2012 | 11:32 AM
Choda's Avatar
Magnum 70mm. Trick stage 2
