Brake Boosting My Truck Video - Help
Old Aug 30, 2012 | 12:29 PM
9 Second Club
Originally Posted by Choda
man these PCs are crazy. What the hell is a brake torque management? and how does it effect the truck.
leaving at 8psi would def get me into the 13s at over 100
I'm not able to look at my tune file right now, but going by memory it's in the transmission side of the tune, and it may be labeled BTM. It should have an RPM window that you can change the number in. It basically makes the truck start pulling fuel, timing, or both to keep you from standing on the gas while the brakes are being applied. This used to keep me from brake boosting past about 1800 RPM.
Old Aug 30, 2012 | 12:42 PM
TrickTurbo's Avatar
Truck Sponsor
I was WOT in 1st gear and 4wd. It wont rev past 2200 and kinda studders there which is only 5psi. Anything in particular causing this? What do you guys think.
YouTube - 70mm Z71 brake boosting
Love it, most would be happy with 5psi brake stalling.
the studder not sure, but if you remove it, you probably will still be at that psi/rpm... The convertor will stop you from going higher, unless you can add a freakish amount of more power.
Now wheres the rest of the video were you dump the brake and get it.?
Old Aug 30, 2012 | 12:49 PM
Spoolin's Avatar
GFYS and STFU
Yeah lets see some action vids! These brake stalling video's are a tease unless there's a happy ending!
Old Aug 30, 2012 | 01:04 PM
Choda's Avatar
youtube 70mm Z71
That was in my parking lot of my work, all the people walking into the building gave me the WTF look. hahaha
Old Aug 30, 2012 | 01:25 PM
tiffo60's Avatar
Brake torque management is located
Engine/Torque Management/General and Left Column on the bottom,
(Disable by TCS) set to enable
(Brake Torque Limit) set to max value
Old Aug 30, 2012 | 01:48 PM
Choda's Avatar
Thanks!!!
I'll ask New Era if they can up it for me to like 3k
Old Aug 30, 2012 | 06:55 PM
black00chev's Avatar
Slowest turbo build ever!
I like this one, moves pretty good... Nice little 10psi spike there on your shift to!
Old Aug 30, 2012 | 09:38 PM
Choda's Avatar
haha thanks
there might be a couple vids u guys like on my channel
Old Aug 31, 2012 | 03:32 PM
thunderwagen's Avatar
I never could get mine to brake stall any boost. As soon as it hit .5 psi i started pushing through my brakes and that was with a 2800 stall. I would be happy with 5 psi all day long especially on a stock converter.
Old Aug 31, 2012 | 04:20 PM
fortplainman's Avatar
jacks if your heading down to leicester tonight try to build a couple #'s in 2wd, im sure you will trap 100 since we both trapped same speed even if mine was 1/2 second slower with no brake boost.
oh and heres a vid:
2012-08-24_20-58-30_347.mp4 video by fortplainman - Photobucket
