br7efs idle like crap
Old Oct 25, 2013 | 06:27 AM
Choda's Avatar
Interesting because once in a while my tr6s do that. Jump around from 400-600 rpm. Could it be injectors?
Old Oct 25, 2013 | 08:32 AM
kelsey_canard's Avatar
I'm going to try messing with the tune some when I get home.
Old Oct 25, 2013 | 08:38 AM
LS1TRUCKGUY's Avatar
Seems like a big gap?? Mine are gapped at .026 with zero issues. Had a slight misfire in the upper rpms gapped at .030 though.
Old Oct 25, 2013 | 08:40 AM
trxmxzx's Avatar
13 Second Truck Club
My tr6's made my start up rough - stalls easy- if I do wot a lot it's starts to foul them out but I know it's because my afr is way to rich- (10.2/8psi)
Curious to the cause of this issue...
Old Oct 25, 2013 | 08:46 AM
Choda's Avatar
My tuner asked me to try the 7s at 28. Im using part number 3346 plug because there are different 7s out there.
Ill try these, do some pulls. if its fixed, golden. if not then Ill go to a looser gap, if still breaking up, then back to tr6s and play with those gaps. kinda sucks changing plugs because I do not have a v band at the bottom of my downpipe and slip joints blow.
Old Oct 25, 2013 | 09:32 PM
TURBHOE's Avatar
the 7's ran like crap on my 5.3 also. maybe my high mileage coils are my idle issue. all stock motor now and even the 6's idle like crap when its raining out.
how many miles do you have on yours?
Old Oct 25, 2013 | 10:04 PM
miles = 1 metric **** ton
Old Oct 26, 2013 | 12:00 AM
Fast86z's Avatar
I run br7ef on my 4.8 and it runs like stock plugs. Not only that but the tips were always clean as a wistle.
I once had a problem in another vehicle when going from a 6 to a 7 ngk plug. I thought it was just too cold of a plug, but after further inspection, it was actually sucking up oil into the intake manifold and oil-foulding the plugs.
OP ought to pull the plugs and inspect them. If they truely are missing due to too cold (carbon fouling), they will be evident on the plugs.
Old Oct 26, 2013 | 03:57 AM
TURBHOE's Avatar
Maybe it is the coils then. Mine is at over 130,000 now and I was running bad wires for a long time. I wonder if that wore the coils out faster. Arcing all over the place vise going to the plugs.
I'm in Japan right now so I can't try it. So I'll be looking to see what your fix is.
Old Oct 26, 2013 | 10:29 AM
Think you can over night me some go fast parts?
