br7efs idle like crap
#31
Motor is burning oil, and is slow lol. So there is a possibility. Compression test showed ~160 on all cylinders.
Edit, may be leaking oil too, but I cannot find from where.
#34
Really think this could be an issue? Any other opinions on this?
#35
Seems like the more timing I added the more vacuum it pulled. 41kpa and about 18 in/hg. IIRC. But the more timing i added, the worse it surges. I find it very wierd with the raf table requiring more air. Maybe it was because I got rid of the pcv system. Does the pcv act as a controlled leak?
Did an ohm test on the wires today. The highest resistance was ~980ohms. All were really close. I bent the crap out of the wires while i was testing them too.
Heres a youtube video of how the timing affects it.
VID_20131027_194650_605.mp4 - YouTube
I will also attach the current tune if anyone cares to check it out. Maybe I fouled the plugs during some tuning. I did mess with the boost some with them in, and im sure I ran it rich as hell.
try cleaning the idle air control motor.
#36
in the video timing looked super low and bouncy. when you raised timing it was all over the place. your wide band also looked like it went lean a few times. sudden lean spikes like that will make it buck like a ****. i have one little special spot on mine that if it hit that one spot it would buck and do all kinds of craziness. richened it up in that one spot and it was good.
#37
#38
There are tables that keep your idle within a given RPM. You might want to zero out those tables to see if it elimates that effect.
