BOV, FPR and Fuel pump booster all referenced off one fitting?
Old Dec 29, 2017 | 02:38 PM
TAPyvehc93's Avatar
Default BOV, FPR and Fuel pump booster all referenced off one fitting?
Just wondering if thats a little to much to be referenced off that one little 1/8 nipple on the side of the intake. The fuel pump booster is located in the rear of the truck too. Should I upgrade to a vacuum block or will the results be the same?
Old Dec 29, 2017 | 06:06 PM
Atomic's Avatar
I have a gauge for that
Bov I would put separate, all the other static sensors are fine off a small hose.
Old Dec 29, 2017 | 06:29 PM
beaner's Avatar
Tcehing In
If your FPR is 1:1 rising rate, you're going to want that independent and direct to the intake manifold ideally. That vacuum line is very important and if you have a failure of any kind there, you're in trouble.
Old Dec 31, 2017 | 09:13 AM
TAPyvehc93's Avatar
Decided to just buy a vacuum block and run off the pcv port on top of the intake since I am no longer using it. Thanks guys.
Pro52R
Apr 26, 2019 10:14 PM
BlackGMC
Jul 16, 2012 11:37 AM
walledition
Nov 5, 2009 10:32 AM
ssavalanche
Jul 28, 2009 07:04 PM
t_thall
Feb 2, 2008 06:24 PM
