Return style fuel system, use fixed fuel pressure or use vacuum referenced???
Well i just got my fuel system all switched over to return style. Currently i don't have the vacuum reference line hooked up so i am running 58-60psi all the time and i left my IFR table the same in the tune.... Basically i made zero tune changes and I noticed my tune stayed the exact same, meaning my LTFTs were +/- 3% as usual. So i am wondering what benefit would I have in hooking up the vacuum reference??
I have a gauge for that
It helps at vacuum by effectively lowering fuel pressure so your injectors act "smaller" than they really are. Exactly the same as raising fuel pressure will make injectors flow more, lowering the pressure make them flow less. Because injectors are electric solenoids with a real delay time, they can be unpredictable at low pulse widths (and highly non-linear), so by lowering the rail pressure you force them to have a desirable pulse width. And similarly at boost pressure it keeps the fuel pressure across the injector constant by raising rail pressure. Keep in mind its the goal of the FPR to keep the pressure difference across the injector the same at all times. Even though the rail pressure will be less, the pressure across the injector is the same because the engine is pulling a vacuum on the bottom of the injector which is exactly the same as pushing harder from the top.
If you do not want to run a reference line to the regulator you need to change the IFR table to reflect the increase in flow at engine vacuum. However, if your wideband shows its fine, the idle and fuel trims are probably absorbing this difference in real and expected flow. But I recommend either setting the IFR table correctly, or leave it constant and hook up the reference line.
Gingervitis Addict
X2. If you hook the line up, just open table B4001 and copy the 0 cell value and paste it in all the other cells. The tune "should" remain the same.
