Bought a used procharger!
Old Mar 12, 2014 | 08:15 PM
gunter96ws6's Avatar
I shot him a pm this am, waiting to hear back. I'm doing as much research as I can in my down time. It looks like my stock 6.2 flex fuel injectors are 54lb at 58psi and the ones supplied with the kit are 52lb so I think I'm in the clear. Still want to hear 100%. Also still unsure if I need to use the flow charger or not.
Old Mar 12, 2014 | 08:42 PM
TIM Z's Avatar
11 sec. Truck Mod
Hmmm , I was told that the FF injectors on my 6.2 were 36lbhr , and the stock pump would support about 600 horse .
So please post if you find out different info .
Great looking truck BTW and congrats on your new boost.
Old Mar 12, 2014 | 09:39 PM
Here are a few links where I read the the 6.2 flex fuel has 54lb injectors.
Fuel injector questions??? - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
For those that have tuned the L9H 6.2 - PerformanceTrucks.net Forums
I dont believe anything I read online for the most part which is why I'm being persistent about finding out for sure.
Old Mar 13, 2014 | 08:24 AM
Vortec350ss's Avatar
Based on the data in HPT they are 50# at 4 bar fuel pressure.
36# injectors are what the 5.3 flex fuel comes with... the 6.2 flex injectors are big.
That said with 50# injectors you can have some fun, but you will run out quick of you try to make serious power.
Old Mar 13, 2014 | 08:50 AM
TIM Z's Avatar
11 sec. Truck Mod
I like that info right there
Old Mar 13, 2014 | 11:00 AM
vettelovralexand's Avatar
I did a P1SC swap on my dad's truck (2011 6.2 E85) and the stock injectors started to fall off at 5500+ RPM. This was on a 3.6 pulley which is probably at 8 to 9 lbs of boost. I got him hooked up with some ID1000s and it is fine now.
Pretty sure Justin at black bear said the factory injectors were 52 or 54 lb for his truck.
Old Mar 13, 2014 | 03:33 PM
gamble686's Avatar
The stock injectors will be okay at first, but the second you start pulleying down and reaching for more power those injectors will start running out. I would skip right to the biggest injectors your pocket feels comfy with. 72s or 80s would be more on the budget side or id1000s if your pockets are a lil deeper.
Old Mar 13, 2014 | 05:00 PM
How can I tell what pulley came on this kit? Measure it?
Old Mar 13, 2014 | 07:27 PM
I spoke with justin at Blackbear and he said my injectors will be fine for 8-9lbs of boost but we will have to disable the e85 option.
blownss27
Aug 14, 2020 08:27 AM
murderedSS
27
Oct 12, 2015 11:13 AM
chopperloco
Sep 28, 2015 08:40 AM
00loudchevy
Sep 11, 2015 07:55 AM
Justin87gn
Sep 10, 2015 12:06 PM
