Boosted crank pulley
Old Mar 18, 2015 | 02:32 PM
6.0l RST's Avatar
Default Boosted crank pulley
What one is best for boost. Don't want to run a stock one .thanx
Old Mar 18, 2015 | 04:14 PM
03sierraslt's Avatar
Do you want to overdrive it? What blower?
If you are not planning to go OD then I don't know what the issue is with the stock one, but none the less.
Old Mar 18, 2015 | 04:43 PM
George C....'s Avatar
Formerly ScreamingL
Ati is one of the best
In past on stock motors I've ran SLP ones
Old Mar 18, 2015 | 06:03 PM
6.0l RST's Avatar
motor is fully forged 6.0l getting an s480 you have the link to the ati that fits the truck can only find ones that are for the cars
Old Mar 18, 2015 | 09:39 PM
Formerly ScreamingL
I run car accessories but if you look up the ATI balancer for the 2010 camaro SS that will fit on the truck
we have one on our TT-NOTCH that uses truck accessories
Old Mar 19, 2015 | 09:51 PM
Gadgetized's Avatar
I'm with Pat on this, I don't see the need to run an aftermarket (unless you needed an SFI balancer). I run a stock one on mine without issues. If you wanted added protection you could always pin it.
If you have your heart set on an aftermarket one or want an underdrive one, powerbond is another option. I had an overdrive powerbond and it was great.
Old Mar 19, 2015 | 10:18 PM
Formerly ScreamingL
there are legit reasons to run a aftermarket damper, especially if you spin some nice rpm, use 2 step or have a built motor
if you go off rule book you do need a SFI one after a certain ET number
Old Mar 20, 2015 | 10:41 AM
Atomic's Avatar
I have a gauge for that
I broke a stock one on the dyno with a turbo. It was one of the earlier ones (99-03 I think) that are slightly thinner on the struts. Replaced it with another stock one though.
Old Mar 20, 2015 | 10:49 AM
blownescalade62's Avatar
Why chance it spend the money put on a ATI
Old Mar 21, 2015 | 06:12 AM
6.0l RST's Avatar
If a camaro ss one fits the truck then I guess I'll explore that route
