Boost guesses on my whipple setup
Old 04-16-2018, 01:17 PM
03sierraslt's Avatar
Originally Posted by Atomic
See pic. About 11-12psi.
You still have that spreadsheet here? I wanna run my numbers and see how close it is.
Old 04-16-2018, 02:22 PM
I have a gauge for that
Atomic's Avatar
Here ya go, have at it. Keep in I basically made up the VE and intercooler efficiencies so that has some bearing on it. The supercharger power required is just based on the aerodynamic load, the real number will be higher due parasitic losses but I dont have a good way to calculate that, so just add like 20% if you want a number.
Also keep in mind I have like 4 different boost gauges for various reasons, and they all read different. So just because the spreadsheet doesnt match your gauge doesnt mean either is wrong. This is just meant to get you in the ballpark.
File Type: xls
ZO6Ted (04-16-2018)
Old 04-16-2018, 06:11 PM
ZO6Ted's Avatar
Very nice to have a resident genius here!
Old 04-17-2018, 06:38 AM
Its pretty damn close to what I actually see, my boost just doesn't fall off with rpm.
Old 04-17-2018, 11:02 AM
snogoer's Avatar
Thanks Richard, I’d be happy around 11-12 psi if that’s what it runs when it’s all put together. Ultimately I’d like to run 12 psi so if I have to down pulley from the 3” when it’s all going so be it.
thanks for the info
Old 09-27-2019, 03:03 PM
RMC_SS_LDO's Avatar
As a complete novice, trying to use the spreadsheet but unable to determine crank diameter. This is for a 5.3 (LC9) engine, but trying to determine what the spreadsheet is actually calculating, not just searching for a number to plug in.
TIA!
Allen
Old 09-27-2019, 03:09 PM
Atomic's Avatar
If you mean mine some of the diameters are on the right, cells L6 through M9. Spreadsheet is calculating a lot of stuff, rows 12 through 32.
Old 09-28-2019, 07:51 AM
RMC_SS_LDO's Avatar
Was asking what should I plug in for crank diameter in cell C7. I plugged in the value from what looks to be defaults in cell M6 but trying to figure out what is actually meant by crank diameter...
Allen
Old 09-28-2019, 08:54 AM
MikeGyver's Avatar
The diameter of the belt pulley on the crank
Old 09-28-2019, 09:11 AM
RMC_SS_LDO's Avatar
Makes perfect sense now!
Allen
Last Call
22
03-14-2005 04:15 PM
Todd@AZPowerAndSound
11-18-2004 07:24 PM
33
10-22-2004 09:50 AM
Chevmann99
09-24-2004 02:46 PM
BigTex
26
11-11-2002 06:17 PM
Quick Reply: Boost guesses on my whipple setup
