Boost drop off in radix lq4
Old Oct 26, 2006 | 10:01 AM
Last Call's Avatar
TOTM: January 2007
Default Boost drop off in radix lq4
Is it common to see boost drop off in the upper rpm range. From 1500-4500 rpm I am seeing about 8-8.5 psi of boost. As it gets to 5-6000rpm, is goes down to about 7 psi at redline. Is this typical??
Old Oct 26, 2006 | 10:26 AM
moregrip's Avatar
what a rush!
I have heard others say similar things. However, I have not personally seen this, I build to 7lbs, and stay there.
Old Oct 26, 2006 | 10:28 AM
dewmanshu's Avatar
Moderately Differentiated
it happens to me, i have less boost than i start with, BUT...you sure you aren't suffering from belt slip or crank pulley spinning?
Old Oct 26, 2006 | 10:33 AM
Last Call's Avatar
TOTM: January 2007
Running a 110.5" gatorback belt and I do not see any belt dust. The crank pulley is pinned. Maybe try another belt. This one is about a year old.
Old Oct 26, 2006 | 12:22 PM
Holty's Avatar
Notorious BIG
i'm running 100mm metco idlers, crank pulley pinned, and a 111.5" gator back with a 2.8" pulley. At 6k rpm i'm at 8psi and it holds steady and somtimes goes up a tad. In the dead of winter, i'll see 9psi.
Old Oct 26, 2006 | 01:08 PM
dewmanshu's Avatar
you have a scan of this happening?
Old Oct 26, 2006 | 02:47 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I do, posted in the Dyno section.
Old Oct 26, 2006 | 04:53 PM
zippy's Avatar
Sounds like belt or crank pulley slippage to me.
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
jaypowe11520
Jul 29, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
NuckenFuts
Jul 9, 2015 08:45 AM
