Boost drop off in radix lq4
Is it common to see boost drop off in the upper rpm range. From 1500-4500 rpm I am seeing about 8-8.5 psi of boost. As it gets to 5-6000rpm, is goes down to about 7 psi at redline. Is this typical??
Originally Posted by dewmanshu
it happens to me, i have less boost than i start with, BUT...you sure you aren't suffering from belt slip or crank pulley spinning?
i'm running 100mm metco idlers, crank pulley pinned, and a 111.5" gator back with a 2.8" pulley. At 6k rpm i'm at 8psi and it holds steady and somtimes goes up a tad. In the dead of winter, i'll see 9psi.
