Boost Creep
Old Apr 13, 2008 | 12:05 AM
SpoolinChevy's Avatar
Default Boost Creep
My creeping problem will never enddd. I put my 3# spring in today along w/ my new gauges. I did a wot run for about 3 or 4 seconds and it was at 10# so i backed out. What in the hell would make me have a 7# creep? We haven't double checked the gauge yet, but i was still experiencing 4#+ creeps before w/ my 5.8# spring and old gauge. I'm pissed!
Edit. My wideband was reading a steady 14.8-15.0 at wot, i thought this was way lean, but the instructions say 14.7 is good?
Here's a pic of my wastegate location.
Old Apr 13, 2008 | 12:20 AM
charcold-bowtie's Avatar
THat 14.7 needs to be like 11.5ish for boosted application. IMO dont even go WOT till it gets sorted out.
Old Apr 13, 2008 | 12:44 AM
It wasn't warmed up yet, but the idle was skipping around from 14.7,14.8, and 15.0. Could this be a minimal exhaust leek, or is she about to crap out on me?
Old Apr 13, 2008 | 01:03 AM
kbracing96's Avatar
Your waste gate is NOT hooked up right in that pic! Your vac/pressure line need to be connected to the port on the side of the WG not the top. There should be nothing on that top port. The way that is hooked up, boost pressure is holding the gate SHUT. That is also WAY too lean for being in boost. are you sure about what it was reading? When driving around, it should be reading in the 14.7 range, but as soon as you start to get into boost it should drop down to the 11.5 range to be safe. Running that lean in boost will break your toy FAST!!
Old Apr 13, 2008 | 01:07 AM
That top port was a vent, now it's connected to my boost controller. hmm, so is this my tuner's fault? Yes, i did 3 WOT runs, that was what it read. Its still in the green stioch range when it reads this too.
Old Apr 13, 2008 | 01:15 AM
kbracing96's Avatar
What kind of boost controller do you have? Take the boost control out and just run strait to the WG till you get it straitened out. Then reconnect it and adjust from there.
Old Apr 13, 2008 | 01:25 AM
i just put the controller on last week. Its a turbonetics manual controller from summit. I'll take a look at it tomorrow. You think maybe my wastegate is not fully opening??
Old Apr 13, 2008 | 02:02 AM
kbracing96's Avatar
I think your boost controller is not properly setup
Old Apr 13, 2008 | 11:53 AM
Prior to controller, it seems to be fine. I dont have a logger, so this is the only other thing i can compare it to.
Old Apr 13, 2008 | 08:29 PM
The controller was backwards. I didn't get all the way in it, but the controller is definitely working now, but the wide band still stays in between 14-15.
