Boost control necessary
Old Dec 11, 2017 | 10:35 AM
13chevy370's Avatar
Default Boost control necessary
Do I need to install one if I'm only going to run about 10lbs. It's my DD.
Old Dec 11, 2017 | 11:18 AM
kbracing96's Avatar
No, Just put a 10lbs spring in the wastegate and run it. A boost controler can only turn boost up from spring pressure.
Old Dec 11, 2017 | 11:27 AM
^^^^^that
Old Dec 13, 2017 | 02:09 PM
MrJimi1121's Avatar
also keep in mind that if you run the boost source from the compressor you will make around waste gate pressure. If you get the source from a vacuum manifold you will make 1.5-2 psi more.
Blown02Sierra
Nov 28, 2009 09:25 AM
zo6freak
May 10, 2007 02:48 PM
johnrusso1987
Apr 20, 2007 10:03 PM
bowtieman81
Feb 15, 2005 01:13 PM
FILE
Jul 7, 2002 10:57 PM
