Boost control necessary
Do I need to install one if I'm only going to run about 10lbs. It's my DD.
No, Just put a 10lbs spring in the wastegate and run it. A boost controler can only turn boost up from spring pressure.
^^^^^that
also keep in mind that if you run the boost source from the compressor you will make around waste gate pressure. If you get the source from a vacuum manifold you will make 1.5-2 psi more.
