boost on 11:1 compression
Old Nov 14, 2007 | 01:54 PM
mcfarlnd's Avatar
Un-Registered User
Default boost on 11:1 compression
my buddy has a question yall might be able to answer.
1st gen 383
carbeurated
I am toying with the idea of boost, my static compression is 11-1, but my dynamic compression is only 9.5-1 with the camshaft that I have, I do not have any detonation issues with 93 pump fuel, as a matter of fact I had to take my timing to 68 degrees before I finally got spark knock(just to know where the limit was at) running at 38 degrees I can run 87 pump fuel still with no problem. 75cc combustion chamber aluminum heads, 6" rods, .163 keith black pop-up pistons, 3.75 stroke, cam @.050 252-258 duration, lift is .631-.630, 110 lobe seperation installed at 106 intake centerline. Any info would help. Does it really matter what my dynamic compression is or not??
Old Nov 15, 2007 | 01:00 PM
mcfarlnd's Avatar
Un-Registered User
anyone?
Old Nov 15, 2007 | 01:25 PM
ZO6Ted's Avatar
Really I would do a bottle instead with your setup. What heads are those?
Old Nov 15, 2007 | 01:29 PM
CHEVRACER83's Avatar
Well Tahts Not An Ideal Candidate For Fi... But It Could Be Done... I Would Say Your Gonna Lose Some BOOST With The Overlap. But I Definitely Would be cautious and raise the boost slowly.
Old Nov 15, 2007 | 03:39 PM
408 Sleeper's Avatar
You should be able to run a lower amount of boost, maybe 5-6 lbs, even more with timing retard. They make forced induction kits for the Z06 Vette's and they have a fairly high compression ratio.
Old Nov 15, 2007 | 04:46 PM
mcfarlnd's Avatar
Un-Registered User
he already has the bottle 250 and 150, he wants the power all the time. 210 eliminator AFR heads is all i know but, ill ask him the specs if that would be helpful..
Old Nov 15, 2007 | 05:30 PM
yeah the z06 has 11.1 compression...
but your cam is helping you bleed off a lil.
they run on a 5psi wastegate spring if i remember correctly
walledition
Feb 24, 2026 03:27 PM
2500ZL1
Sep 12, 2015 03:50 PM
11MPG
Sep 10, 2015 08:34 PM
Boyes50
Sep 8, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
