blown guys PCV system??
Old Nov 5, 2005 | 05:52 PM
14 Second Truck Club
I had an open air breather and a check valve. I had the check valve where the PCV would normally be(04 doesnt have one) and then the breather on the passenger side with the throttle body capped off.
Old Nov 5, 2005 | 06:09 PM
02sierraz71_5.3's Avatar
Originally Posted by greentahoe
the only prob I see with that is that under vacuum the intake provides the vacuum to pull the air/oil mix through the catchcan/ breather. I think putting a check valve in line is going to be the best way to set this up and get the most out of it. It seems not many spend much time on this. I find that strange.
i agree it is strange since alot of these engines will suck up a quart of oil in 6k miles and it can cause detonation. Im just gonna plug my intake line a put a filtered breather on the crankcase. That way I know no oil is being consumed from GM's thoughtless engineering in this area. Plus I"ve noticed spuradic tip in KR sometime and I really think its from the pcv sucking in alot of oil with drastic throttle variations. I installed an older ball type pcv and it did help with consumption but the end all is just to illiminate the damn thing
Old Nov 5, 2005 | 06:12 PM
greentahoe's Avatar
Thats pretty much what I ended up doing. I just made the catchcan/ breather and hooked it up to the lines coming from each valve cover. I just plugged the manifold.
Old Nov 5, 2005 | 08:44 PM
I have no shame in saying I have no idea what you guys are talking about. lol
Is this something I need?
Old Nov 5, 2005 | 11:13 PM
greentahoe's Avatar
yes. Its pretty important for us boosted guys. How is your PCV setup? It may be different. You have one line coming off the passenger side valve cover(unless in the whipple install you swap valve covers) and one coming out of the drivers side at the back going to the intake manifold.
BKnBLK05
Dec 28, 2015 08:52 PM
The_W
Oct 28, 2015 09:00 PM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mzay
Jul 6, 2015 11:03 PM
