Blower Cam
Old Apr 5, 2016 | 03:30 PM
musclecity85's Avatar
Default Blower Cam
I was looking for a cam for lsa swapped 08 Silverado z71. It has 3.73 gears, 2800rpm converter, longtubes, 3 inch exhaust, ill be making between 12-16lbs of boost. I was looking at this cam 215/232 .609/.599 113+1 TVS Stage 1 would this work well or should I try something else? is there a recommend cam I should try or that would suit me better?
Old Apr 5, 2016 | 04:19 PM
Vortec350ss's Avatar
Tell us more about the set up. LSA blower, or a complete LSA motor?
If its just the LSA blower, I assume you have adapter plates? 5.3?
Old Apr 5, 2016 | 07:46 PM
It's a 5.3, Lsa lower, zl1 lid, 2.5 upper pulley, %10 overdrive crank pulley,(estimating about 12-15lb of boost but not sure lol) 80lb injectors, adapter plates, Olson customs Lsa acc drive kit. Truck has longtubes, 2800 rpm converter, 4l60e tranny, I'll b fabbing a custom 4in intake. 3in exhaust. Going to a Sd tune.
Old Apr 7, 2016 | 12:23 PM
embs2001's Avatar
I think you over pullied for that 5.3.
Are you 6 rib or 8?
Old Apr 7, 2016 | 01:21 PM
SSnation's Avatar
Sounds like a good cam. What kind of power are you looking to achieve?
Old Apr 7, 2016 | 02:57 PM
SUTTERERMAN85's Avatar
2.5" on my LSA Blower 5.3l is 13lbs with a small cam and stock exhaust.
Old Apr 7, 2016 | 02:59 PM
low to mid 500s
Old Apr 7, 2016 | 03:00 PM
Are you 6 rib or 8?
6 rib currently
Old Apr 7, 2016 | 03:01 PM
i have longtubes and a 3 inch exhaust. so im sure ill lose a lb or 2 of boost due to that..
Old Apr 7, 2016 | 03:17 PM
I assume you have the adapter plates to make the blower work on a 5.3?
