Blower Cam
Old Apr 7, 2016 | 07:02 PM
musclecity85's Avatar
I assume you have the adapter plates to make the blower work on a 5.3?
yes..just waiting on the accesory drive kit to come so i can start putting it all together
Old Apr 8, 2016 | 05:36 AM
About20ninj45's Avatar
What fuel rail did you go with?
Old Apr 8, 2016 | 10:42 AM
vettelovralexand's Avatar
That 2.5 upper and 10% OD is going to put you into the 20 PSI range (if it doesn't slip) and your exhaust being restrictive will make that number go UP not down. I run a 10% OD lower and a 3.3 upper and am in the 10-11 PSI range. My cam is a 219/234 on a 118+6 from BTR and I made 518 RWHP.
Old Apr 8, 2016 | 11:17 AM
using the ls9 rail since the feed is on the drivers side just like stock
Old Apr 8, 2016 | 11:21 AM
wow 20psi!! maybe ill swap the stock lower balancer back. would it be better to go to a 4 inch exhaust? or true 3 inch duals? since I already have headers
Old Apr 8, 2016 | 12:17 PM
Mainesfinest's Avatar
id love to know as much info as you can give on this setup. anything special with the install?
Old Apr 8, 2016 | 12:49 PM
The stock damper should drop you back 2-3 psi, but will still be north of 15 PSI.
As far as the exhaust is concerned, both flow about the same with (2) 3 inch pipes having about 10% more total flow area. It is probably more of preference and packaging that would dictate an answer. I think a single 4 is likely a lot easier to fit.
Old Apr 8, 2016 | 01:02 PM
Vortec350ss's Avatar
This guy knows whats up!
I agree with his posts.
Old Apr 8, 2016 | 01:08 PM
Trying to save you the trouble so you can get your truck tune lined out. Waiting patiently for you to hit the track!
Old Apr 8, 2016 | 02:19 PM
I'll go back with the stock damper then.
So is it better on take the 3 inch off the Y pipe and straight to a 4inch exhaust straight back? And thanks for the advice. Also would a 4 inch intake be enough to feed the blower?
