Blower air temps?
Old Jan 17, 2020 | 11:34 AM
03sierraslt's Avatar
Originally Posted by terravast4
maybe a big *** heat exchanger
The real solution is a bigger intercooler for the manifold
Old Jan 17, 2020 | 11:41 AM
terravast4's Avatar
true.. kinda on the small side. with the phenolic spacer you could add a larger intercooler
ZO6Ted's Avatar
Fwiw I saw a 14 deg rise during a 0-75 blast. Returned back to normal after stopping. Not long enough.
Old Jan 17, 2020 | 01:12 PM
madmann26's Avatar
When I was running 14psi on my Whipple 2300, it would get to 140’ish on a hard, sustained pull.
It did cool down quick however.
Old Jan 17, 2020 | 01:42 PM
BigKID's Avatar
Kenne Bell 2.8L on built 370 at 15psi. Spinning compressor at ~85% max speed at shift point.
With upgraded heat exchanger and pump - +15 degrees over ambient on cruise and +120 on a full boost pass.
Prior to upgrades - +30 cruise with continual heat gain / +180 full pass
Old Jan 17, 2020 | 05:30 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by smokinlmm
At 14 pounds I'm making some heat, I'm at 125 to 130 at the end of the 1/4 but I drive it an hour to the track so it's throughly heat soaked.
where is the air temp sensor those temps aren’t bad at 14on a blower
Old Jan 17, 2020 | 05:35 PM
TrickTurbo's Avatar
Truck Sponsor
Wonder why y’all see 15-20 over ambient.
The Lightning see’s much higher air temps.
So we built them a large ic. to help.
Anyone here pushing 20+?
Old Jan 17, 2020 | 05:36 PM
TrickTurbo's Avatar
Truck Sponsor
yea those air temps are killing performance.
Old Jan 17, 2020 | 05:40 PM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Last Call
Are you thinking of something for us blower guys?
yes, but 20-30 over ambient isn’t not bad.
& the juice might not be worth the squeeze.
procharger customs are enjoying the ability to run our larger inter coolers.
but not much offered to the blower guys. 🤷‍♂️
Old Jan 17, 2020 | 05:52 PM
dantheman1540's Avatar
There aren't many bolt on front mount heat exchanger upgrades dedicated to the trucks. Nor are there any complete packages such as a bigger pump, ice box, heat exchanger and all associated lines to connect them. Everyone seems to buy their preference of each part from different vendors and make their own stuff.
