best factory head casting for a turbo 5.3?
so if you had a choice of any factory casting what would you pick? is the 862 the best for a street driven vehicle because it keeps the compression up or would 241's be better?
Stock, you over think the setup it will run horrible. 317's on a 5.3 is a bad idea. There are alot if guys making 18-23 pounds of boost in the stock heads. Higher compression will make more boost you just need to control detonation by using meth or e85
Choda
Jan 22, 2026 02:03 PM
