View Poll Results: which belt do you like better?
Goodyear Gatorback
70.83%
Gates
25.00%
other, please post info.
4.17%
Voters: 24. You may not vote on this poll
which belt slips the least?
Old Sep 14, 2006 | 01:41 PM
Holty's Avatar
Notorious BIG
Default which belt slips the least?
my engine bay is covered in belt dust. i never had this problem until after i installed the metco 100mm pulleys and switched to a 111" belt from my previous 110.5" but i could NOT get that one back on. i havn't really been driving the truck much lately, so i never thought about this problem too much. now race season is coming up quickly for me. i'll have a very limited timeframe to make it to the track and i want to put down some good numbers. need some suggestions on eliminating this problem. also, please vote for your favorite belt that slips the least.
Old Sep 14, 2006 | 02:08 PM
dewmanshu's Avatar
Moderately Differentiated
maybe possibly your belt is too small. I have the same setup as you and I do have dust, but not everywhere. When I lost my belt at the track and Bryan(Breeze) helped...errr put it back on for me he even noted it was way to small. Just a thought.
I didn't vote, as I have never changed between them and noted any differences.
Old Sep 14, 2006 | 02:16 PM
KySilverado's Avatar
I voted Gatorback. I am running 2.9 pulley, recently added the 100 Metco's but went a long time with the stockers, and the original 112.5 belt length. I have minimal if any belt slip. I have never seen dropped boost via the gauge. I have noticed a little dust on the pullies and blower snout bracket. I have noticed that there is a little more dust when I put a new belt on but lessens after a little break in. I've had to replace the belt a couple times when its jumped off, damaging the belt and breaking the idler arm.
moregrip's Avatar
what a rush!
I run a gates 112.5" belt and don't have any issues with a 3.1 pulley
Old Sep 14, 2006 | 04:00 PM
03sierraslt's Avatar
I have had great luck with the gatorback, my gates would slip.
Old Sep 14, 2006 | 06:39 PM
hrodgmc's Avatar
Gatorback
Gates Green Stripe (they seem to get sticky when hot)
Dacco Poly Cog
Are my preferences in order.
Old Sep 14, 2006 | 06:53 PM
Breeze's Avatar
11 Second Truck Club
Holty I allway's notice more belt dust with a new belt As Kysilverado stated above. I run a gate's belt's but I'm not saying it's better then the other's.
Old Sep 14, 2006 | 06:59 PM
krambo's Avatar
My gatorback will "chunk" a little for the first 100 miles or so and then there is no sign of belt wear. The stocker (radix kit) was bad. I would have enough dust to actually pinch off the alternator bracket. The gatorbacks have been great for me.
Old Sep 14, 2006 | 07:03 PM
thunder550's Avatar
High on diesel fumes
2.8 pulley, metco 100mm idlers, and a 110.5 inch Gatorback belt. I still get belt dust. Runs at about 8.5 psi max on my boost gauge.
Old Sep 14, 2006 | 07:37 PM
camcojb's Avatar
I prefer the Gates; on the Lightnings the Gatorbacks seemed to have more slip issues as they have less surface area. It was a hot topic, but the Gates never slipped up to 22 psi on mine.
Jody
