beautiful twins
Old 05-09-2006, 11:47 PM
  #101
duwem's Avatar
Originally Posted by Yellowsierra
Yep thats the same thing I got. I only paid $5.70ea which I though was an awesome deal.
what ever happened to yoru twins, looks identical to parish's setup...you disappeared?
Old 05-10-2006, 09:58 AM
  #102
Yellowsierra's Avatar
My manifolds only lasted about 4 weeks. I just made them out of 18ga. material but they started cracking and warped up really bad.
Old 05-10-2006, 10:17 AM
  #103
vanillagorilla's Avatar
I don't know if you two are too far along, but this is an interesting alternative to fabing your own from scratch.
https://ls1tech.com/forums/showthread.php?t=504243
Old 05-10-2006, 01:01 PM
  #104
duwem's Avatar
wheel to wheel's truck turbo setup just flipped the stock header on the passanger side and bolted the turbo to that, they made some mad power with it
Old 05-10-2006, 01:06 PM
  #105
single digit dreamer
parish8's Avatar
i tried sticking the stock manifolds on the truck in diferent ways and didn't see any way to make it work. that gto manifold might have worked but i doubt it. any fliping of the manifolds would then require running the plug wires from the bottom so you have to add that work into it if you are considering that route.
Old 05-10-2006, 01:33 PM
  #106
Guy's that's not a truck manifold or a GTO manifold. Its the 5.3 manifold off of a front wheel drive GP, and as far as anyone knows it's never been done. The angle is totally different than a truck and car manifold. I think this is the same manifold that's on the Impala SS too.
Old 05-19-2006, 11:58 PM
  #107
parish8's Avatar
got the 2nd header done.
i looked for a place to put the waste gates up top where you can see them but it will just be easier to put them down low. i have room to put one right off the end of one header and the other hanging off the bottom of the header. the down pipes look prety easy but i dont have a tranny right now so i dont know how much i want to do.
i got a few more parts on the way. i got 2 of the intercoolers that were on my last kit on the way and 2 of the bov's too. also 2 of the hard rubber elbows that were on my last kit. things are coming together slowly. total spent so far, $4700 i am prety sure this project will break $6k. i did get most of my money back from selling the pt88 kit so that helps.
Old 05-20-2006, 12:16 AM
  #108
Keith's Avatar
Looking damn good.
Hows the air cooled torch working for you on that lincoln?
Old 05-20-2006, 12:22 AM
  #109
James B.'s Avatar
man that's nice...
Old 05-20-2006, 12:32 AM
  #110
parish8's Avatar
Originally Posted by Keith
Looking damn good.
thanks, lincoln seems to work good but this is the first time i have used a tig so what do i know.
Quick Reply: beautiful twins
