Attn: NewFrontMount Turbo requires a helmet!
Performance Trucks Sponsor
All I can say is, "awesome"!!!
The owner of the Trick Performance Turbo truck and I went out to the track tonight and ran a best!!
To recap: '06 Sierra ext cab, 4x4, 33" tires, toolbox, full street trim, transgo shiftkit, 42lb injectors, upgraded fuel pump, Trick Performance front mount turbo 5psi, Nelson installed and tuned.
The truck ran a 13.77 @98.88 mph!!!!
60' was 2.08x
If anyone is considering a forced induction kit for their truck, this kit is blowing away any kit on the market!
I don't think any other kit can claim 3.1 secs drop in the 1/4 mile with 5psi, to my knowledge.
The turbo allows a full boost launch with the stock converter.
Once the holidays pass, we'll try to head back out there and run a 13.5sec, I know the truck is capable of it.
We'll swap some stock tires on it (these heavy 33's are probably robbing about 50hp), remove all the xmas presents in the back, lol, and see what happens.
Tonight was 68deg and high humidity. The intercooler did it's job, intake temps were about 74degs in the stages lanes, about 84deg after a test launch and 72degs at the end of the 1/4 mile.
We'll have a video posted tomorrow. It shows us staying up with an older motorcycle, beating a transam and a few other cars.
This kit has surpassed any of my expectations and beyond,
thanks for listening,
allen
60' was 2.08x
allen
60' was 2.08x
allen
60' was 2.08x
allen
Might need to be careful before you know it, a roll cage will be on the list. lol
Originally Posted by CHEVY6000VHO
No 6.0L kit yet Allen?
Sounds like this kit is producing great power. What are the kits capable of producing in terms of a maximum safe boost level?
Jim
Jim
12.2 we were using the A2W intercooler.
Originally Posted by thunder550
Nice! What would need to be changed to make the kit work with a T76 and a 408?
Thanks guys,
I'm sure this setup in a rcsb would run in the low 12's. This truck weighed in at about 5700lbs. I think this is over a 1,000lbs more than a regcab.
Plus, it has larger tires and added weight.
This kit is about to go on a rcsb with a 6L swap, ls6cam, 80eswap, t76, 10+psi, right JJ,
we'll keep you updated,
allen
allen
