Attn: NewFrontMount Turbo requires a helmet!
Old Dec 16, 2006 | 12:15 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Default Attn: NewFrontMount Turbo requires a helmet!
All I can say is, "awesome"!!!
The owner of the Trick Performance Turbo truck and I went out to the track tonight and ran a best!!
To recap: '06 Sierra ext cab, 4x4, 33" tires, toolbox, full street trim, transgo shiftkit, 42lb injectors, upgraded fuel pump, Trick Performance front mount turbo 5psi, Nelson installed and tuned.
The truck ran a 13.77 @98.88 mph!!!!
60' was 2.08x
If anyone is considering a forced induction kit for their truck, this kit is blowing away any kit on the market!
I don't think any other kit can claim 3.1 secs drop in the 1/4 mile with 5psi, to my knowledge.
The turbo allows a full boost launch with the stock converter.
Once the holidays pass, we'll try to head back out there and run a 13.5sec, I know the truck is capable of it.
We'll swap some stock tires on it (these heavy 33's are probably robbing about 50hp), remove all the xmas presents in the back, lol, and see what happens.
Tonight was 68deg and high humidity. The intercooler did it's job, intake temps were about 74degs in the stages lanes, about 84deg after a test launch and 72degs at the end of the 1/4 mile.
We'll have a video posted tomorrow. It shows us staying up with an older motorcycle, beating a transam and a few other cars.
This kit has surpassed any of my expectations and beyond,
thanks for listening,
allen
Old Dec 16, 2006 | 02:12 AM
JJ_TURBO's Avatar
11 Second Truck Club
Thats great Allen, I can't waite to get mine install.
Old Dec 16, 2006 | 01:04 PM
ogkevin13's Avatar
Banned
really respectable times and only at 5 psi niceeee
Old Dec 16, 2006 | 01:10 PM
tarinitup's Avatar
9 Second Truck Club
Sounds like it a bad *** kit
Old Dec 16, 2006 | 06:46 PM
raisinkane's Avatar
Geez..wonder what that kit would do on a RCSB?
Mine must be at least 800-1000 lbs less weight.
raisin
Old Dec 16, 2006 | 08:54 PM
Question
No 6.0L kit yet Allen?
Sounds like this kit is producing great power. What are the kits capable of producing in terms of a maximum safe boost level?
Jim
Old Dec 16, 2006 | 09:03 PM
thunder550's Avatar
High on diesel fumes
Nice! What would need to be changed to make the kit work with a T76 and a 408?
Old Dec 16, 2006 | 10:09 PM
TrickTurbo's Avatar
Truck Sponsor
60' was 2.08x
allen
Allen nice numbers for sure. Isn't the truck also required a drive shaft loop(s) now.
Might need to be careful before you know it, a roll cage will be on the list. lol
Jim
Right now the Trick Performance Products 6.0L 2500HD has pushed 12.2 lbs using the 62-1. I turned it down to a 9.5 on the daily driver. Trany woes keeps this truck from going to the dyno.(one minute all works next thing has alot of trouble shifting into 2 and 3rd gear)
12.2 we were using the A2W intercooler.
The larger turbo ONLY. The layout allows that turbo to be bolted right up.
Old Dec 16, 2006 | 10:34 PM
FarmTruc's Avatar
Thanks guys,
I'm sure this setup in a rcsb would run in the low 12's. This truck weighed in at about 5700lbs. I think this is over a 1,000lbs more than a regcab.
Plus, it has larger tires and added weight.
This kit is about to go on a rcsb with a 6L swap, ls6cam, 80eswap, t76, 10+psi, right JJ,
we'll keep you updated,
allen
Old Dec 16, 2006 | 11:02 PM
thunder550's Avatar
I'm going to be keeping a close eye on the progress of this kit, I'll be ready for one as soon as I finish paying for my 408.
