Anyone using Variable Geometry Turbos?
Old Nov 28, 2007 | 08:31 PM
Spoolin's Avatar
GFYS and STFU
Default Anyone using Variable Geometry Turbos?
Just as the topic states, is anyone using Variable Nozzle Turbines/Variable Geometry Turbos on their trucks or cars?
Only production vehicle that I know of that uses it is the 2006 Porsche 911 Turbo. Was wondering what people's opinions and reactions are to them if anyone does run them.
Old Nov 28, 2007 | 08:53 PM
explorer5.0's Avatar
TOTM: November '07
the 6.0 PSD diesels (and lots of modern deisels) use them. Unless you had a good way to control the vanes, they would be a waste of time for the aftermarket. The PSD version uses oil pressure controlled by a solenoid to move it's vanes.
Old Nov 28, 2007 | 09:03 PM
nightrunner's Avatar
Mr. Obvious
the duramaxes have them.
i dont know of anybody that has one and can control it. i have heard of a couple of guys slapping duramax/powerstroke/cummins turbos on motors but they cant control the vanes
Old Nov 28, 2007 | 09:15 PM
Bo185's Avatar
VW TDI Diesels have them. And they are vacum operated via a solenoid.
Old Nov 28, 2007 | 09:23 PM
Spoolin's Avatar
GFYS and STFU
Yeah I know the Diesels are running them but more curious about gas engines. Only production one I know if is the 911 turbo. How hard or what is involved with fabbing up a vacuum operated solenoid to work with a gasoline engine?
Old Nov 28, 2007 | 09:37 PM
TOTM: November '07
There was a guy at theturboforums that rigged a PSD turbo onto a 5.0, and made a manual controller for the vanes- I cant seem to find the thread though.
Old Nov 28, 2007 | 09:41 PM
Spoolin's Avatar
GFYS and STFU
Would it be worth it you think?
Also I thought the Ford power stroke Diesels used two turbo's in series to deal with the low end and high end boost. Are they also VGT's?
Old Nov 28, 2007 | 09:44 PM
Bill Reid's Avatar
IMO, I don't think the aftermarket has come to embrace variable geometry turbo's just yet... with the fact that increased management complexity, and the costs associated with it, will yield $/Hp results that will be favorable enough to support selling the technology and making a profit. Just a thought
Bill
Old Nov 28, 2007 | 10:08 PM
WJ MARK's Avatar
I pretty sure pontiac solstice uses it and so does the saturn. Stays small to spool quick then it opens up.
Old Nov 28, 2007 | 10:35 PM
Wilde Racing's Avatar
How do I change this text
International uses them too. (maker of the power Jokes) The I6 internationals, used a stepper motor to control the vane, which for us would be the easiest to set-up for our use. I thought about getting few, but cost (650 for just the motor) and the fact it is one part that fails more than any other part on the engine....
