Anyone flipped their passenger side manifold
Old Mar 6, 2012 | 03:29 PM
  #31
nodrok's Avatar
Ok the exit side of the waste gate. Nice. I miss understood the other guy im sure that what he meant my mistake.
Old Mar 6, 2012 | 09:15 PM
  #32
wld1985's Avatar
Originally Posted by nodrok
That's definitely not a pipe for a waste gate. I bought most of my cold side pipe from eBay and cut it. You need to go get it beaded after you cut it thought. Make sure you use t-bolt clamps, not worm gear on all your silicone.
Speaking of beading..Look what I found during my search,Pretty neat how the guy made it..
Cheap Tubing Bead "Roller" - Club Cobra
Old Mar 6, 2012 | 10:22 PM
  #33
Jake99's Avatar
hmm wouldnt see why that wouldnt work, just take a little time.
Old Mar 7, 2012 | 12:28 AM
  #34
nodrok's Avatar
Lol that bead actually looks pretty good. And your forearms look like poppy when your done.
Old Mar 9, 2012 | 11:12 AM
  #35
nodrok's Avatar
Anyone else running a flipped manifold turbo set up?
Thanks for all the replies guys.
Old Mar 10, 2012 | 09:41 AM
  #36
t_thall's Avatar
heres mine i built a few years back:
https://www.performancetrucks.net/fo...-mount-426454/
Old Mar 10, 2012 | 06:17 PM
  #37
nodrok's Avatar
any heat problems with the AC. I was wondering if i will need to modify my AC lines to keep them away for the exhaust cause i need to run a 5" down pipe.
Old Mar 10, 2012 | 06:57 PM
  #38
kbracing96's Avatar
5" dp??? You plan on making 1500hp??
Old Mar 11, 2012 | 09:36 AM
  #39
Jake99's Avatar
yeah theres just no way you can fit a 5inch dp with a flipped manifod in there. I did a 3.5 dp and theres no more then a paper thin gap betweem the dp and the manifod and the dp still rubs a little from time to time on the frame. You might get a 4inch in there If you put bends in there and squezzed around everything.
Old Mar 11, 2012 | 11:04 PM
  #40
nodrok's Avatar
No maybe 1000. I don't want to downsize my down pipe. It comes off turbo at 5".
