Anyone flipped their passenger side manifold
Old Mar 5, 2012 | 06:44 AM
bud8fan's Avatar
mine is the same as davids accept im running a gt45 turbo.
Old Mar 5, 2012 | 07:27 AM
nodrok's Avatar
Thanks again guys keep the pics coming. Well looks like thats what im gonna do. Im gonna fab up my own hot side.
Do you guys need to put any over the plug wires to keep them from melting?
Old Mar 5, 2012 | 07:52 AM
Here is mine I used manifolds from an 02 LS1 camaro and both of mine are flipped up
Old Mar 5, 2012 | 08:02 AM
ducky's Avatar
Originally Posted by f4tal
I like that overflow tank David!!
Picked it up off Jegs for like 80 bucks!
Originally Posted by TimDave217
so in this setup you kept the driver side manifold the same and just ran the cross-over behind the motor similar to the kb, and trick kits, but went up to the turbo? if so that sounds like a lot of piping in that small area! lol.
Yeah the crossover was custom fabbed, but it goes behind in the same location as the stock Y pipe, and meets back up in the engine to the turbo.
As you can see above on o2camaross, a lot of guys are running it in the front with good results. I personally wouldn't do it like that because of the appearance factor, but its working nonetheless.
Old Mar 5, 2012 | 08:24 AM
Like David said, mine works very well, but it is different than just about everybody else lol. Its not the prettiest but in person, its pretty cool looking, just not as clean as putting the crossover behind the engine. Lots of ways to skin a cat
Old Mar 5, 2012 | 12:11 PM
nodrok's Avatar
Thanks for all the pics they help big time. I like coming across the front with the driver side manifold because you use a lot less hot pipe. think i may turn both of mine round now. Looked like you eliminated your ac. Im planning on keeping mine so that will take a little work as well.
Old Mar 5, 2012 | 12:46 PM
Yea I dont have A/C but Im pretty sure the compressor would work just fine with my setup
Old Mar 5, 2012 | 05:13 PM
nodrok's Avatar
Did you try doing your turbo build with the truck manifold first is that why you had to go to the 02 car manifolds?
Old Mar 5, 2012 | 07:36 PM
Yea , I had the truck manifolds, the 02 LS1 manifolds, my 2010 LS3 camaro manifolds and LS1 GTO manifolds and the fbody manifolds worked the best. My roommate is using the LS3 manifolds on his 2002 camaro and we are building a twin setup on his
Old Mar 5, 2012 | 08:35 PM
03RCSB's Avatar
I flipped my stock truck manifolds, kept the AC and ran across the front. More build pics here
https://www.performancetrucks.net/fo...t-more-491848/
