Any tips on cam, springs & other valvetrain, crank pin kit for Radix?
Old Sep 6, 2010 | 03:22 PM
  #81
1Bear's Avatar
Tom, your oil pick-up tube o-ring being red, it should be part number 12584922, unless the part number has changed. Due to you still using a beehive style spring, the valve-seals will be a one-piece seal/seat arrangement, in which case you can just use a socket that will just fit over the outside of the seal, so that you’re actually driving down on the seat. They are a press fit, but it will not take much effort to install them and you will know by the sound, as well as the feel when the seal has seated in the head. If you were to install seals on either an older style motor or if you were installing dual valve-springs that use the separate seat and seal arrangement, I don’t condone installing the seals with a socket, as it can damage the seals. In this case you should use a valve seal driver such as the one pictured below:
Now it doesn't have to be fancy billet aluminum, it can simply be made out of Teflon®, but never the less it is the safer approach for a long lasting set of seals.
Old Sep 6, 2010 | 05:05 PM
  #82
Atomic's Avatar
I have a gauge for that
I got the Kentmoore J-42078 valve installer thing off ebay for $12
Old Sep 6, 2010 | 05:52 PM
  #83
1Bear's Avatar
Pretty darned cheap for peace of mind.
Old Sep 6, 2010 | 08:15 PM
  #84
fastnblu's Avatar
Ya, I knew mine used 1pc. seal / seat. Starting in 2001 goin forward used the 1pc.; 2pc preceded that.
skolman91, I didn't get a LS6 pump, cause we have the same pump I was told. It if wasn't a Titan or blueprinted (I think SLP does it), I couldn't see spending the coin. I've 75,500 miles on my truck. Yes, a 10 or 12mm deep socket can be used to seat the valve seals. I too thought I'd read a skt. could be used, so I had to go find what size they said.
If I can't get 1 quick, a 10/12 milli deep we have to get it. But $12 is quite reasonable, considering how much some tools can cost (including those for this job).
Old Sep 6, 2010 | 08:26 PM
  #85
GMCtrk's Avatar
75k is like new.
Old Sep 6, 2010 | 09:11 PM
  #86
1Bear's Avatar
To drive the seal on by striking it against the seat, instead of the seal itself, I’m afraid you’re going to find you need a socket closer to a 20mm and not a 10mm or so. Don't worry, they will drive on easily.
Old Sep 6, 2010 | 09:20 PM
  #87
fastnblu's Avatar
Apparently, the link I've been workin w/. was wrong: they said 10/12mm deep. Not arguing, just sayin what I read. Either way, I've got both.
Leave the sq. drive on top, & have at it w/. whatever size it may be.
Old Sep 6, 2010 | 10:22 PM
  #88
1Bear's Avatar
I know where you read that, they are just driving them from dead on top of the seals, which I believe you should avoid if possible. It's pretty much otherwise a very good write up and helpful to allot of people.
Now change them damn springs already and keep us updated…….LOL
Old Sep 6, 2010 | 10:47 PM
  #89
06murder's Avatar
what does rcsb stands for?
Old Sep 6, 2010 | 10:55 PM
  #90
Atomic's Avatar
regular cab short bed
