Any ProCharger guys ever run the HoB DD bracket system?
#62
8 Second Truck Club
Just for comparison, I got 1 pull on the dyno when I had the iron 347 and the d1sc w/8-rib. Calculated blower speed was 106% at 7000 engine rpm.
I only got one pull to 6000 due to the trans not holding. At 6000 rpm, it was making around 18-19 psi. I think I had about 16* in it at the time, on c16/pump mix. It made 695 at the tires.
Just for you to reference when you turn it up.
#63
unfortunately, no
5.7L LS1 thru a 4L80e...
Thanks!
What size compressor pulley were you running at the time?
Nice.
