Any one runnin a cam close to this?
Old Sep 28, 2007 | 12:06 PM
Raffman's Avatar
Default Any one runnin a cam close to this?
220 226 @.050 564 570 It's a comp cam and I'm looking to put it in the 6.0 build (.030 over forged,stage 2 heads & 10lbs boost) The cam choices seem endless for these motors and I'm sure this one will make power but what about street manors, mileage, etc? Any one have this or close to it that can chime in .Thanks.
Old Sep 28, 2007 | 12:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What is the LSA?
Old Sep 28, 2007 | 01:59 PM
Raffman's Avatar
OOPS, sorry its a 114 LSA which ATI recommended to keep to 112-114 for the procharger.
Old Sep 29, 2007 | 02:17 AM
03sierraslt's Avatar
Should be a good cam for that setup. With your stall a slightly larger cam may even be better however for all around driving I think that would be a good choice. I am going a hair smaller then that in mine but my stall is also a 2600-2800 not a 3300 like yours.
Old Oct 1, 2007 | 07:05 PM
BigKID's Avatar
That is a tad smaller than the one I had speced for my 370ci/KB 2.8 combo. 223/229 114+4 Cam Motion lobes. I have only run it N/A thus far as I am in the process of installing the KB now. So far the cam is great with my 2400 stall converter. It lacks a little bit below 1500 under load with the converter locked but think the boost will compensate that once the blower is on.
Old Oct 1, 2007 | 08:26 PM
jasond26's Avatar
I ran a cam a bit smaller, 220/220 566/566 in my 370. It was on a 120lsa. Idled like stock and made good power. That cam you have should make good power all around and idle with a little hint of rumble. Should be awesome.
Old Oct 2, 2007 | 07:15 AM
Raffman's Avatar
Wow, a 120 lsa. Was that with the F1 ? I thought with a FI the lsa should be around 112-114 ?
Yes can't wait to hear the new motor,looks like its going to be a winter project though.
Old Oct 2, 2007 | 10:19 AM
dhpro's Avatar
214/218 .559/.562 @ 114lc...here's mine...not too sure its the right one tho...have IAT prob and it cud be a valve event issue. 12ish* overlap (thats what they say anyway), and the motor doesn't seem to appreciate it. We'll find out today if thats the real prob tho. R/
rednekferlife101
32
Jan 8, 2016 10:42 PM
Jake99
Aug 8, 2015 07:56 AM
Blackrat48
Aug 4, 2015 09:52 AM
rojeho
Jul 12, 2015 06:10 PM
