any one going 9's with a 4.8 yet?
Old Aug 26, 2014 | 11:28 PM
foose04's Avatar
Mine went 10.17@134 with a soft 1.57 60. That tune up made just under 800HP on the dyno. However I got a little carried away with how easy the truck made power and turned her up another 120+HP before ever getting back to the track. I think a setup 800HP 4.8 in a truck lighter then my full weight 4580 (leather, a/c, towing package, load bags, amps/subs) fat chick setup, should go 9s no problem.
https://www.youtube.com/watch?v=CqV-...zdqzneihreqv04
Old Aug 26, 2014 | 11:41 PM
oakley6575's Avatar
Soft 1.57
My **** would be rock hard if I cut that 60'.
Old Aug 26, 2014 | 11:48 PM
foose04's Avatar
Lol, well if I didn't red light all night that night as I was racing No One, maybe the two step could of popped a couple more times to help her get back into the 1.49s she had a few times at that track.
Old Aug 26, 2014 | 11:58 PM
oakley6575's Avatar
Thats pretty sick man. I'm going to see what I can cut with hydroboost and a converter change but might end up ordering a Jakes trans brake. We'll see what my turd will cut before I go that route.
I'm anxious to see how all you other 4.8L guys do. Has anyone besides Foose even been deep 10's with the 4.8L? I've seen a bunch of 10.75's or so but not low 10's.
Old Aug 27, 2014 | 01:04 PM
LOWnEASY's Avatar
Are you running a leaf setup in the back foose? Or link?
Old Aug 27, 2014 | 02:36 PM
oakley6575's Avatar
Pretty sure he is leaf spring with caltracs.
Old Aug 27, 2014 | 03:40 PM
foose04's Avatar
Oakley is all over it. Non-Flipped, Leafs with Cals, no overload.
Oakley, good luck with the hydroboost. I have heard mostly good things about it.
Old Aug 27, 2014 | 03:42 PM
oakley6575's Avatar
Oh I read up on your truck Thanks for the luck. I'll need it.
Old Aug 27, 2014 | 04:09 PM
LOWnEASY's Avatar
When you going to push that new setup in the 8's foose?
Old Aug 27, 2014 | 05:07 PM
black4.8's Avatar
I am doing everything I can just to see 10's so trust me it isn't easy. I had a horribly loose converter holding me back (25% slip up top). had Coan custom make one, should be good there now. weight down to around 4000#. power should be 700rwhp now. soon as temps get a little lower i'll see what it does.
