Any ideas
Old Mar 5, 2014 | 09:16 PM
BUTTERB30's Avatar
Default Any ideas
So i got done installing the turbo kit on my 4.8 sierra and now it say i have low oil pressure , and the only thing i did was add the oil feed line from the side of the engine under drivers side and tap hole for drain in very front of oil pan. Hooked OIL gauge up and it reads nothing.
any ideas anyone???
Old Mar 5, 2014 | 10:19 PM
oakley6575's Avatar
Just to clarify, you hooked a mechanical gauge up and it read zero??
Old Mar 5, 2014 | 10:39 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Is there an oriface in your oil feed line? Are you reading the factory oil pressure gauge, or have you connected a manual oil pressure gauge?
Old Mar 6, 2014 | 02:21 PM
BUTTERB30's Avatar
i might have did it wrong but i hooked a guage on the turbo adapter plate on the side and not were the oil sender goes cause its so dang hard to get to but that way read nothing and the trucks display says low oil pressure
Old Mar 6, 2014 | 02:23 PM
BUTTERB30's Avatar
and it was a gauge we use for testing pressures for all cars so i know the gauge works
Old Mar 6, 2014 | 02:33 PM
GRRR65GTO's Avatar
How did you add the line. Drilled and tapped the block off?
Old Mar 6, 2014 | 04:09 PM
BUTTERB30's Avatar
yes for my return line i had to drill and tap. i went with the very front of the oil pan just under the crank pulley like i saw member CHODA had done
BUTTERB30's Avatar
mine is a little right of that
Old Mar 6, 2014 | 05:24 PM
GRRR65GTO's Avatar
I was asking about your supply line
Old Mar 6, 2014 | 06:14 PM
BUTTERB30's Avatar
OH sorry bud all i had to do it remove the cap above oil filter and ad the adapter and screw on oil line and run to turbo. its the oil set up i got from trick performance ive used previously with no problems
