Another "Turbo Build Check List" Thread
Old Aug 21, 2018 | 10:43 AM
BT802's Avatar
10 Second Club
Yea the FIC's have data as well and a local shop is a dealer.
One thing I didnt realize until now is that I may not be able to drop the 450 in my stock bucket. I didnt plan on doing a return setup.. now I'm not sure which way to go. We were planning on knocking it all out Friday-Sunday since it's the daily.
Old Aug 21, 2018 | 11:03 AM
chevykev's Avatar
is it flex fuel? I have a flex fuel and I’m going to do uncapped uscar injectors I got for 125$ should flow 70lbs at 58psi f/p and shooting for 5-600hp on 12# when I finally pull the trigger. About to install a Vette Servo and super hold servo and I’ve had a tranny cooler and my stock trans has 133k on it now. Might freshen it up tune it and see what it can hold
Old Aug 21, 2018 | 11:19 AM
BT802's Avatar
10 Second Club
No, non flex fuel. I'm wondering if I should snag a bucket off Ebay to throw the 450 in so I can just swap the entire thing at once.
I used decaps with my GTO and had 2 crap out on me after being cleaned and flowed, not going that route again.
Old Aug 21, 2018 | 01:12 PM
chevykev's Avatar
yea j feel you. I’m not sure how to make the 450 fit into the flex bucket but I’ve seen some guys custom make them but I rather not go through that trouble. Especially if flex pump will hold to about 5-600hp stock form. Im trying to find someone that makes a kit to drop in the flex fuel trucks. But think non flex fuel should be hard? If I don’t use the decapped injectors I might use the 80# in the turbo kit I’m looking at
Old Aug 21, 2018 | 02:25 PM
BT802's Avatar
10 Second Club
The issue is the bucket I have has a built-in regulator that doesn't work with the 450.
Old Aug 22, 2018 | 07:01 PM
BT802's Avatar
10 Second Club
I'm going to pick up a stock flex fuel pump assembly and go from there. It's looking like its a direct swap and will support what I'm wanting to do.
Old Aug 23, 2018 | 08:04 AM
chevykev's Avatar
With that cam and turbo no problem 500+ may even be able to hit 600 but idk about the pump after that. Do you have the parts already? Remember post pictures please lol
Old Aug 23, 2018 | 07:05 PM
BT802's Avatar
10 Second Club
I have pretty much everything sitting here with the exception of that fuel pump assembly that I'm going to order. Hopefully that ACDelco MU1847 works as well as I read on here.
I'll try to get as many pics as I can. We're starting with the DOD stuff first, not sure if you care to see that or not lol.
Old Aug 25, 2018 | 12:54 AM
chevykev's Avatar
Yea I do thanks
Old Aug 25, 2018 | 01:00 AM
megabuddys's Avatar
You mentioned that its a crew cab. So its a big heavy truck obviously. I think you can do better choosing a different cam. Reach out to Stock48 for a suggestion, the one you have chosen may work well for a light car, loose converter, but in your truck with the little 5.3 a smaller duration one would be so much better for all around Driving IMO. I had an isky triple 12 cam (stock48's specd cam) in an NA 5.3, then turbo'd and it was a hoot to drive. I personally am not a fan of the Circle D converters, I have never seen one that isn't too loose. This isn't a race car your building, it still has to be tolerable to drive or you will hate it. With a better cam, you could tighten up the converter as well.
For the trans, you don't need a Super servo or anything for 4th. If it had a Blower on it maybe, turbo no. A 4l60 has no business getting power put down in 4th gear especially in a heavy vehicle. You would be surprised that a simple .500 boost valve, and a Corvette servo (that is installed correctly with the right Servo clearance) Willl allow the trans to hold a bit of power and last awhile if the trans is in decent shape. Keep the torque management in, it, just cut it down at low throttle; there is some tuning tricks here. Get the bugs worked out, when you decide to raise the power level save up for an 80 and be done with it.
06sierra5.3
Jun 16, 2011 11:30 PM
RickLowpez
Aug 26, 2009 03:09 AM
RickLowpez
Aug 7, 2009 01:20 AM
moregrip
May 21, 2005 08:47 AM
FarmTruc
48
Sep 16, 2002 05:33 PM
