Almost done w blower install, have a question
Old Aug 17, 2012 | 06:19 PM
jiar577's Avatar
Default Almost done w blower install, have a question
Almost done with the Roush install, truck is an '06 NBS and the only thing left is installing the intercooler wiring harness.
There's a relay, a ground, a connector for the pump and couple of cables, one has an eyelet at the end and the other has nothing at the end.
Where do I connect those two?
Old Aug 17, 2012 | 06:24 PM
TIM Z's Avatar
11 sec. Truck Mod
What color are the wires ?
Im going to get out my install instructions..........
Old Aug 17, 2012 | 06:34 PM
jiar577's Avatar
Both are white, but the one with the eyelet is a bit thicker or wider in diameter.
Old Aug 17, 2012 | 06:36 PM
03sierraslt's Avatar
Couple of cables? If I recall there should be a fused power wire, a trigger wire, and a ground. The other two wires should connect to the pump harness.
Old Aug 17, 2012 | 06:37 PM
TIM Z's Avatar
11 sec. Truck Mod
Basically one with the eyelet is gounded, other wire is a turn on when key is on.
Old Aug 17, 2012 | 07:45 PM
TIM Z's Avatar
11 sec. Truck Mod
Ok bud here is how mine is hooked up,
Black connector plugs into pump
One white wire is grounded to firewall or inner fender or somewhere convenient.
Other white wire says fuel pump relay on it, it can be wired to the grey fuel pump wire in your main harness, or to another wire that is energized when the key is on, this is so your pump only runs when the key is on.
Hope this helps.
Old Aug 18, 2012 | 09:30 AM
jiar577's Avatar
Hope this helps.
Tim, found the gray cable that comes from under the tank all the way to the fuse panel. Black connector into pump as stated.
There're 2 cables with eyelets at its end, one is a thin cable (like 20 or 22) and the other one is like three times larger in diameter. Which one goes to the firewall? The larger one I assume?
What about the one that's left?
Old Aug 18, 2012 | 06:49 PM
TIM Z's Avatar
11 sec. Truck Mod
The white wires have labeling printed on them, one says " fuel" , that one goes to the grey fuel pump wire, other wire goes to ground bud,
Let us know.
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ammadien
Jul 22, 2015 08:50 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
