alky control
Old Aug 24, 2012 | 08:31 PM
  #41
9 Second Club
Originally Posted by fastnblu
That factory warning is pretty slick. I still want a bed mount. Somehow.
I know what you mean. I'm guessing that's for capacity reasons? It's been my experience with my corvette that a windshield washer tank full will last for several tanks of fuel. And I run a dual nozzle setup on the car.
Old Aug 24, 2012 | 08:40 PM
  #42
fastnblu's Avatar
Originally Posted by 121
Is this a dual nozzle? On nnbs I'm pretty sure you would have to put nozzles after maf. And after BOV.
No BOV on a S/C.
Just not sure what would be similiar to a turbo's BOV.
Why run a dual nozzle vs single?
What advantage?
Every several tanks, but it varies as it's in boost or not I'd think?
Stay outta boost, consumes less meth, right?
Old Aug 24, 2012 | 08:50 PM
  #43
9 Second Club
What advantage?
Stay outta boost, consumes less meth, right?[/QUOTE]
Dual nozzle for more flow at high boost levels. The car makes 750rwhp. Usage is directly related to time in boost if you have it set to come on at low boost. I have mine to come on at 6lbs and go to full pressure around 8lbs. I plan on running the truck single nozzle coming on at 4Lbs and full pressure at 8lbs. With an output going to the electronic boost controller that will prevent it from going over 8lbs if it's not at full pressure already.
Old Aug 25, 2012 | 09:15 AM
  #44
121's Avatar
121
No BOV on a S/C.
What advantage?
Forget a lot of you are blown!
Old Aug 26, 2012 | 09:24 AM
  #45
philntx's Avatar
Julio installed my kit himself. It looks like it came that way from the factory. Went with a single nozzle kit. Tank was installed in the jack compartment in the rear. Vented to the outside, stainless steel braided lines. Controller mounted inside the center console.
Old Aug 26, 2012 | 09:43 AM
  #46
fastnblu's Avatar
Any & all pics, whether it's the controller in console or the engine, or esp. the jack area, I wanna see em.
SS94S10
Jan 3, 2019 01:57 PM
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
