Air Filter Directly on TB?
Old May 14, 2006 | 11:39 PM
Blown02Sierra's Avatar
Default Air Filter Directly on TB?
If i run a speed density tune and delete my maf, would it be safe to put my air filter directly on my throttle body? Would that be safe? Is it a bad idea?
Old May 14, 2006 | 11:47 PM
F8L Z71's Avatar
I was gonna try to run mine that way this weekend but my filter is too large and will hit the hood and most likely fall off or bend up lol.
I dont see why it owuld cause a problem. Plenty of turbo guys run a filter directly off the intake with no problems. Im thinking of trying to find a flatter filter to do just that.
thunder550's Avatar
High on diesel fumes
You would be pulling hot air from behind the radiator....I wouldn't do it....but it would work fine.
Old May 14, 2006 | 11:53 PM
F8L Z71's Avatar
In all truthfulness I doubt the IATs would be much different unless you have a true blocked off intake and pulled the headlight out while racing. If you already have a good intake system though then this would be usless and possibly detrimental My problem is my air filter doesnt fit my current pipe too well and it falls off. I do run the 1/4 with my headlight out though = total ricer
Old May 14, 2006 | 11:56 PM
thunder550's Avatar
LOL...I finally got around to putting in a good CAI, been running the stock airbox the whole time. Now I will be running without the headlight as well
The stock airbox pulls through the fender though, so even if there is some restriction it's still getting cold air. Unless it heats up anyway in the tube between the airbox and the throttle body?
Old May 15, 2006 | 12:10 AM
well, i had to modify my k&n airbox when i got the radix, and now its trying to make its way through my hood, and i dont feel like fixing anything else, so i figured i'd ask you guys about that. F8L_Z71, i didnt even think about that. It probably would hit unless i got a HD hood. I was also thinking about the heat issues. What could i do about an airbox? should i delete my maf when i get efi live?
Old May 15, 2006 | 07:58 AM
silver-mod-o's Avatar
Hunt&Fisherator
K&N makes a flatter rectangular or oval shaped filter thats slimmer that just the big round ones. I am guessing that would work. I know we've all seen it done on 'vettes with limited space there. I would think that if you have that kind of room up front that making some type of ram air system would be better that just sticking it behind the radiator as mentioned. those two slots in the front of my bumper pad look like good candidates for a ram air system once I get the fan shroud and junk out of the way with some e-fans.
Old May 15, 2006 | 08:31 AM
F8L Z71's Avatar
The other issues would be how much HP you are making. On the FI trucks making big powewr, putting a longer intake tract could hurt power, especially the longer the piping becomes.
Old May 15, 2006 | 08:44 AM
TG02Z71's Avatar
Like on the STS system??
Old May 15, 2006 | 08:48 AM
Hunt&Fisherator
true.. I guess on a Radix if you could get it to work or come up with the shortest path possible for the inlet tube then you'd be better off. I have a tendency to think more along the lines of n/a applications.
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Sep 15, 2015 08:28 PM
Rockrz
Sep 13, 2015 12:22 AM
cousblake11
Sep 9, 2015 06:52 PM
