AEROCHARGER? Anyone heard of these turbos or used them?
Old Feb 12, 2011 | 08:04 PM
Three6GMC's Avatar
Default AEROCHARGER? Anyone heard of these "ZERO" lag Variable vane turbos or used them?
Found a pretty interesting website of a turbo that is self contained variable vein and with there kit on a G8 makes 10lbs of boost before it hits 2k RPMs! WOuld be pretty interesting to see one of these turbos end up on a truck, would make it really really easy to go turbo. Anyone heard of them or used them? Heres a link to there site...
http://www.aerocharger.com/index.php
Tested and proven, the Twin-Aerocharged Pontiac G8 GT is the world's fatest G8 with stock internals. No engine modifications and only our twin-turbo system, this car ran an 11.008 @ 130mph. This car is finishing the prototype phase with 18,000 miles on the turbo kit. On the highway the turbochargers are capable of getting up to 25 MPG due to the VATN system, yet it is still making mild boost at 1,100 RPM. Kick the throttle open and there is 10 pounds of boost before you get to 2,000 RPM. Explosive power from pump gas. No engine or transmission modifications aside from the addition of twin 66-series Aerochargers. Absolutely no turbo-lag, a well documented characteristic of the Aerocharger. Less backpressure, cooler charge, no oiling issues all add up to superior reliability and performance.
Old Feb 12, 2011 | 08:37 PM
04SilverCrew's Avatar
What's the valve off the side? Is that a variable pitch turbo or something? Not sure how well the self contained oil system would do with the high temps those see. Looks like a quality kit though.
Old Feb 12, 2011 | 08:50 PM
Three6GMC's Avatar
The valve on the side acts as a wastegate to adjust boost and supposably the self contained oil system has been proven to last and be a very dependable system. Heres some info I found on the self contained system these turbos use...
INTRODUCTION
Turbochargers, by design, use the flow and expansion of exhaust gases to rotate a turbine wheel, which in turn spins a compressor wheel within the intake stream of the engine. This wheel creates boost by compressing the air and increasing the engine’s mass flow rate. This process however, is directly relative to how fast the turbine wheel is spun by the exhaust gasses passing by it. Boost can only be made once these wheels are spinning up to certain speeds and compression can occur. The delay before boost is built is simply known as turbo lag.
VARIABLE AREA TURBINE NOZZLE
In 1976 a group of turbomachinery engineers wanted to improve on the design of conventional turbochargers and eliminate turbo lag from the equation. The end result was the Aerocharger, a turbo that which utilizes exhaust gases in the most efficient way possible to build boost instantly. This was achieved through a Variable Area Turbine Nozzle (VATN) design for the turbine section. VATN is a series of variable-vanes that optimize the flow area of the turbine by adapting to the exhaust gases. By doing this, the turbine wheel is able to operate at peak efficiency throughout a wide RPM range, something that has never been achieved before. This also eliminates the need for a wastegate, which conventional turbochargers rely upon to control boost. Instead, the vanes automatically adjust the flow area and backpressure to perfectly match the torque requirements of the compressor wheel to produce the desired boost. Eliminating the need for a wastgate means eliminating extra cost in your turbo system. A typical high-performance external wastegate is commonly priced anywhere from $250-$1000 depending on brand and size. Boost is controlled via various shims and spring designs within the vane controller. This also eliminates the need for a manual or electronic boost controller which can also get very costly. These are additional components that are not necessary with an Aerocharger as it relies on no external components to perform.
BEARING DESIGN & LUBRICATION
A unique self-contained oil system was also created for the Aerocharger which lubricates the ball bearings in a fine mist of oil. Since the oiling system is separate from the engine, a proper lubricant can be used for the precision ball bearings instead of using oil formulated for engines. This differs from conventional turbochargers that use a flooded bearing system which rely upon the engine’s lubrication system. By avoiding the use of a flooded design a virtually frictionless, self-contained bearing lubrication system was achieved.
Aerocharger Cutaway
Conventional Turbocharger Cutaway
Conventional turbochargers use a flooded journal or ball type bearing centered between the turbine and compressor housings. This bearing assembly is plumbed into the engines lubrication system where hot motor oil is constantly pumped through it. In many cases, particularly production turbocharged engines, this bearing assembly has separate cavities for the engine’s coolant to flow through to aid in cooling the bearing as well. Motor oil is not particularly designed for high-speed, ball-bearing aftermarket turbochargers, thus falling short of providing the most ideal lubrication conditions. This type of lubrication system is also less than desirable when it comes to hot shutdowns. When a turbocharged engine has been run hard the oil and turbo reach extreme temperatures. Shutting the engine off during these conditions stops the flow of oil, which allows the oil to sit in the turbo and cook leading to bearing wear and premature turbo failure. A common remedy for this would be to allow the engine to idle for a period of time before shut down, or to apply a turbo timer, which does this automatically.
The proper solution for this issue is a turbocharger that does not fall victim to these circumstances. The bearing assembly within any Aerocharger is specifically designed to cater to these needs. Viewing the diagrams on this page it is first easy to see the difference in location of the bearing assembly between an Aerocharger and a conventional turbocharger. With the Aerocharger the bearing assembly is located in the coolest location of the turbocharger: the compressor housing inlet. Fresh air is drawn in around the bearing, effectively drawing heat away from the bearing assembly at all times.
Lubrication of this bearing design is also far different from conventional turbochargers. A cavity is built into the front portion of the compressor housing. A specially formulated high-speed bearing oil resides within the cavity. This oil is transferred to the ceramic ball-bearings via a pair of wicks through which a mist of oil is drawn to lubricate the bearings. Due to the fact that only a light mist of oil is lubricating the bearings, as apposed to the bearings being flooded, the amount of drag on the bearings is significantly reduced (see charts for comparisons).
Low rolling resistance coupled with a low-mass rotating assembly and VATN technology is why turbo-lag is virtually non-existent with the Aerocharger. This also eliminates the need for a turbo timer as the bearings are low drag and hot oil cannot cook the bearings like conventional turbos. Therefore hot shut-downs are not longer and issue and a turbo timer is another component you will not have a need to purchase. A further advantage of this self-contained lubrication system is the fact that the turbo is no longer reliant upon being lubricated by the engine itself. There are no high pressure or lines or seals to fail and reduced oil leakage into the engine for low particulate emissions. This also allows for more mounting options to be available for the turbo including both horizontal and vertical installations
This oil system has been proven not only over several decades of aftermarket installations, but also on military applications where units have logged over 35,000 hours at 83K RPM which is the equivalent of full boost for most applications. The combined results of both technologies allow for optimum reliability, vastly superior performance, and flexible installation. Most importantly boost is achieved virtually instantly.
Old Feb 12, 2011 | 08:54 PM
Three6GMC's Avatar
Some videos...
http://www.youtube.com/watch?v=1trhs...layer_embedded
http://www.youtube.com/watch?v=glskv...layer_embedded
Old Feb 12, 2011 | 09:15 PM
smokeshow's Avatar
Mod with training wheels
Is it just me, or is that manifold pressure graph saying that their turbo builds boost faster than a PD blower? Not only that, but the PD blower only reaches full boost by 6000rpm... I can read through all kinds of cool stuff about their product, but after seeing that I become a bit of a skeptic.
Old Feb 12, 2011 | 09:27 PM
262_NBS's Avatar
it's possible with a variable geometry turbo.....which is what I think this setup uses
Old Feb 12, 2011 | 09:35 PM
kbracing96's Avatar
I found them a while back, Emailed them a couple times with no response about becoming a dealer. Did some more research and apparently the owner/inverter of them died and so did the company. Not sure if that's still the case. Very interesting turbo's, but expensive and failed often and costly to have rebuilt, but that was a year or so ago when I did this...
Old Feb 12, 2011 | 11:42 PM
There a few guys that have them on there can am spyders. One guy fubared an engine but can't remember if it was the turbos fault. I was thinking about puttin one on my spyder but at a $5000+ tag, I will wait a while. As for being shut down, they're still a sponsor on the spyder site.
Old Feb 12, 2011 | 11:58 PM
Daryn's Avatar
Formerly darynC-10/23/10
very neat concept, but thats just more parts that could fail.
Old Feb 13, 2011 | 01:40 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I think that if the technology was really so much better, then they wouldn't be the only company making turbos like this. I'm pretty sure that the bigger turbo manufacturers would adapt the technology if it was any good.
