Advice needed. 10.8:1 on <9PSI?
Old Apr 17, 2010 | 05:42 PM
DOA's Avatar
DOA
Default Advice needed. 10.8:1 on <9PSI?
Hey Guys,
I need some advice. I originally was not going to go FI right a way, but than I bought one of those Ebay TVSs.
The problem is that I had already purchased some TFS 205cc heads by AFR. The Chambers are 58cc and if my math is right, I will end up with a static CR of 10.8. (Love it if someone double checked me.) LC9 Gen IV
I also am planning on putting in a Vinci Trucker Cam at the same time. 218./224 @.551 115 +4.
I've heard that those Rouch TVSs Run at about 9psi on a 5.3. It would be great if someone could confirm that who has installed one. I'm guess that my supporting mods will take that down a bit, which will be nice.
So my question is, will this setup run well for a DD? I don't plan on upping the PSI at all, so the stock pulley will stay in place forever.
Thanks guys,
DOA
Old Apr 17, 2010 | 05:44 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It's all about the tune. If tuned well, you'll be just fine.
Old Apr 17, 2010 | 05:47 PM
DOA's Avatar
DOA
Thanks Man. What heads are you running?
Old Apr 17, 2010 | 05:53 PM
Nothing special. These.
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Material: Aluminimum
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Old Apr 17, 2010 | 06:38 PM
1BADAZZSS's Avatar
Thats a decent # in compression. You go to low of a compression motor and it will be a sluggish DD when out of boost. But yea its all in the tune.
Old Apr 17, 2010 | 07:00 PM
DOA's Avatar
DOA
Can someone confirm my compression? Or that these dimensions are right?
Bore - 3.78
stroke - 3.62
gasket - .051
gasket bore - 3.90
chamber - 58
deck to piston - 0ish?
Piston relief - 0
Thanks
Old Apr 17, 2010 | 09:21 PM
MikeGyver's Avatar
I come up with 11.65:1, with 0 deck, flat top pistons, using the above numbers.
Old Apr 17, 2010 | 09:40 PM
MikeGyver's Avatar
-5 cc dished piston will give 10.725:1
Old Apr 17, 2010 | 09:42 PM
MikeGyver's Avatar
-10 cc pistons will give 9.94:1
Old Apr 17, 2010 | 09:50 PM
DOA's Avatar
DOA
Holy cow, is that right? I have flat tops. What calc are you using?
