adjusting a bypass valve on a Magnuson TVS1900
Old Jun 9, 2013 | 12:28 PM
  #21
TX Tahoe Z71's Avatar
Nice! What is the process for swapping the springs? You get the heavy spring from Magnacharger?
Old Jun 9, 2013 | 12:55 PM
  #22
JCunningham's Avatar
I got the bypass valve from Black Bear. you dont replace the spring you replace the hole assembly. you have to remove the Alt and vac hoses on the sc. then there is 2 7mm allen bolts that hold the valve on. you move the valve and arm until you can slide the rod out. put the new one on in reverse. then you adjuster the set screw until it touches the arm and your set.
Old Jun 9, 2013 | 08:42 PM
  #23
Gotcha, thanks. How much it cost, if you don't mind disclosing?
Old Jun 9, 2013 | 08:44 PM
  #24
03sierraslt's Avatar
So does the new one hook up like mine to the front of the blower? Can you feel a difference in the spring pressure on the rod?
Old Jun 9, 2013 | 08:53 PM
  #25
yes it hooks up right behind the TB. the spring is twice as stiff as the light spring. $75
Old Aug 17, 2018 | 05:50 AM
  #26
01FormulaTA's Avatar
@JCunningham do you happen to still know the part number for the bypass with the Heavy Spring??
zblee
Nov 11, 2015 12:41 AM
MikeD.
Oct 13, 2015 08:08 AM
chopperloco
Sep 28, 2015 08:40 AM
lycominghunter
26
Sep 25, 2015 07:50 AM
bagged7104SS
Sep 24, 2015 08:42 PM
