99-02 behind grill 4” intercooler
Old Feb 10, 2019 | 04:51 PM
Achdog's Avatar
Default 99-02 behind grill 4” intercooler
alright so I’m getting ready to start my install on my 02 4.8 rcsb. Kit I have came with a 4” IC. Upon looking behind my grill, there ain’t a ton of room for anything! I’m thinking I’m gonna have to hack up the a frame, tuck the IC right up against the AC condenser, and find some room for the trans cooler (maybe between rad/condenser? I’m looking for ideas/advice from anyone who’s done a behind the grill IC on a 99-02. Pics of your IC piping/routing would be helpful as well. The headlight brackets will of course be hacked up to get the 3” pipe through.
Old Feb 11, 2019 | 01:39 PM
TrickTurbo's Avatar
Truck Sponsor
By chance have you contacted
The person that built the kit?
Old Feb 11, 2019 | 06:34 PM
Beatdown Z's Avatar
Laid Back
I mounted my 4” ic the way you described and still had to trim the lower part of the grill. I also mounted the trans cooler in between the radiator and condenser. The engine does have some cooling issues in real hot weather. Going to try a radiator upgrade someday...
Old Feb 11, 2019 | 09:25 PM
Achdog's Avatar
hmm yes I’ve now heard that from a couple fellas, that the 28” rad is not up to the task. The 34” rad will just make things that much harder to route pipes around. What fans are you running?
Old Feb 12, 2019 | 08:26 PM
Beatdown Z's Avatar
Laid Back
F-body fans. That’s actually another place for improvement. They don’t fit very tight to the radiator. I’m probably loosing some efficiency with the big gaps on the sides...
Old Feb 27, 2019 | 01:58 PM
Sevex's Avatar
Snail Fab
Check out my build thread, i have mine done exactly as your looking to do
Ferocity02
Jul 1, 2020 11:45 AM
walledition
Mar 19, 2015 08:49 AM
denali_on_26's
Feb 9, 2012 07:29 PM
cfaluck13
Aug 13, 2011 09:38 PM
silver-bullet
Oct 22, 2006 01:07 PM
