78mm to 90mm throttle body
Old Nov 6, 2015 | 12:59 PM
Vortec350ss's Avatar
Awesome!
Old Nov 6, 2015 | 01:02 PM
flatblack83's Avatar
I'm slowly collecting parts to get all the fueling and air needs before a cam swap(vortec350ss). i figured i would get what ever needed so i have that much ready or done. A set of 60lb injectors and a walbro pump will be next. I plan on 10-12 psi or boost, nothing crazy since i would like to keep the bottom end alive.
Right now i have the 48lb injectors and the walbro 190 that the maggie came with. With running a 2.8 magnuson pulley i see 10psi now and i seem to have no lean issues if i go by my afr gauge. I still have 6 rib belts but i don't see any belt slippage at the moment.
Old Jan 5, 2016 | 08:51 AM
stealthperf's Avatar
Are you building this for off road or street? Just wondering if you ran it at a track to check your times? I have an 04 set up about the same way and have no local tracks. Mine is set up for street.
Old Jan 5, 2016 | 02:39 PM
It's basically just a street truck, no track times. I'm just doing this to help performance and to tow my trailer a little better. I'm not sure how fast it would be being so big and geared like it is. It runs good but it's no race car. We will see how it goes after the cam, od pulley, meth kit etc. If I think it's fast enough then maybe by chance I'll run it.
Old Jan 5, 2016 | 10:04 PM
Sounds good. I put a tvs1900 on mine to pull my bass boat better.... Now it's kinda become a mission on how good I can get it to run.
Shtbox
Jan 4, 2016 08:30 PM
tim wellington
Dec 30, 2015 03:59 PM
stylinfosho
Nov 10, 2015 10:45 AM
anothersteveg
11
Nov 6, 2015 10:29 PM
vVandals909
Oct 31, 2015 09:33 AM
