78mm to 90mm throttle body
Old Oct 30, 2015 | 06:56 PM
flatblack83's Avatar
Default 78mm to 90mm throttle body
03 2500hd, tvs 1900 6.0
I have a few questions for you guys that swapped the 78mm ls1 throttle body to the ls2 90mm. Is their a noticeable differance..? For the coolant throttle body hose do you just bypass the throttle body..? Instead of running the xlink is did anyone ever try repinning the harness or try moving the pins or connecting them together, i looked at the wiring diagram for the 6 and 9 pin. The 5v referances will be the only catch......i will be looking into this..lol.
Old Oct 30, 2015 | 07:24 PM
ezdaar's Avatar
Yes, by pass the TB with coolant line.
Old Oct 30, 2015 | 07:30 PM
03sierraslt's Avatar
Re pinning will not work. It uses a different logic, x link is required.
Old Oct 30, 2015 | 07:45 PM
Did you try it, I know repinning wont work totally. Its not that easy, there are 2 5v referance signals too. Ill try it, ill hook one up and then them both. Ill hook the tech 2 up when i do it and see what codes come up. I will mess with it for a while b4 i give up..lol.
Are the gold flap throttle bodies ok to use..? Im not doing any crazy boost, 12 will be the most.
Old Oct 30, 2015 | 08:56 PM
Yes I've messed with it and I've also had 12-13psi suck the ls3 closed.
Old Oct 30, 2015 | 09:02 PM
What style do u prefer..? The ls3 is supposed to be more responsive a quicker. The all silver ls2 style are hard to find under 300.
Old Oct 30, 2015 | 09:18 PM
I didn't notice any difference response wise but there is no doubt the LS3 motor is weaker and that makes the LS2 preferred. Yes unfortunately they are more expensive, I have numerous scans showing the ls3 sucking closed. Currently have the LS2 and at 15-16psi it stays at 100%
Old Oct 31, 2015 | 03:54 AM
Ok, thanks for there info on that. I will keep searching for an ls2.
Old Nov 6, 2015 | 11:47 AM
I received in the mail today an ls2 90mm and an x link, i have a 4 inch aem intake tube that was on my truck before the magnacharger. Its aluminum with a silicone end on each end. Is that ok to use or will it take heat..? Also for a daily driver do i stay with maf or go speed density..? if maf what ones suggested or speed density what iat sensor do you suggest..?
Old Nov 6, 2015 | 12:34 PM
Tube should work fine. How much boost you plan to run?
