6,8 & 10 Rib Belt info
Old Jul 1, 2012 | 05:41 PM
03sierraslt's Avatar
Default 6,8 & 10 Rib Belt info
Since this is a fairly commonly asked topic I figured it was time to sticky info about belt sizes and availability. I will keep adding info as I find it or as people send it to me.
You can search for sizes here
Product Catalog
Here is a complete Gates belt Part # listing along with sizes. This link does not have every size, seems to be more common ones.
http://www.gates.com/oreilly/PDFs/SizeListings.pdf
Lots of good cross reference here, as well as size look up.
Access Dayco
Goodyear Belt Info
Gatorback® Poly-V Serpentine Belts | Goodyear® Engineered Products
Old Apr 1, 2015 | 08:40 AM
Atomic's Avatar
I have a gauge for that
Default Gates Belt Part Numbers
So I extracted some pages from the Gates master catalog to find the belts that may be useful for us. I did this mainly for supercharged setups, but you could look up any belt as long as you know the width. I divided it into 2 files, one with normal belts, and the second one with HD belts. There is not as large of a selection with the HD belts though, so you may have to settle with a normal one.
I extracted the 6rib through 14rib belts. They have the most by far of 6 and 8 rib belts.
The 3rd digit (2nd number) is the number of ribs, ie. K08xxxxxx is an 8 rib belt. They are sorted by part number in the first part and then by length at the end.
File Type: pdf
File Type: pdf
RustyD
May 23, 2016 07:04 PM
slimchevy2
Oct 4, 2015 08:02 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Silver8ado
Sep 30, 2015 11:42 AM
murderedSS
Sep 27, 2015 10:16 PM
