6.3 Stroker 94mm Turbo Ran a shameful 13.4
Old Dec 25, 2015 | 02:40 PM
Originally Posted by TrickTurbo
So you have a custom can and a stick convertor?
Like George ask who's turbo kit need some info there.
Oversized AR? What size AR? What size exhaust wheel?
Who's turbo?
Looks to be a few mismatched parts here.
Yes. I'm running a custom cam and stock converter. The turbo kit is custom fabbed locally. The turbo is a Bullseye Power 94mm BatMoWheel which you can see here http://www.bullseyepower.com/product.../#.Vn2YopN97dQ
Also, I think the AR is 1.50. As for the exhaust wheel size, I'm not sure of that. Maybe you can tell from the link.
Thanks
Old Dec 25, 2015 | 03:09 PM
TrickTurbo's Avatar
Truck Sponsor
Custom kit.
How's it laid out?
Old Dec 25, 2015 | 03:10 PM
03sierraslt's Avatar
Big turbo for 383ci. What are the cam specs.
Old Dec 25, 2015 | 03:28 PM
Custom kit.
How's it laid out?
It's a typical lay out with a BOV and an external wastegate venting to atmosphere. I could try to take some pictures for you if you'd like.
Thanks
Cam specs are 224/242 .629”/.629” 118 LSA +4 advance (with 1.7 ratio rockers)
Old Dec 25, 2015 | 03:32 PM
TrickTurbo's Avatar
Truck Sponsor
Yes pics needed to help sort out your issue.
In thinking just mud matched parts. But it could something else.
Old Dec 25, 2015 | 03:40 PM
Ok. Will take pics in the a.m. since it's night time here. Thank you.
Old Dec 25, 2015 | 04:16 PM
JordanH's Avatar
Restricted
The stock converter and gears are definitely hurting you, especially your 60'! My truck is a complete pig from a dead stop with the factory converter! I need atleast 20ft before it gets its *** in gear! And I'm sure the aftermarket cam with the stock converter is making it worse on you
Old Dec 25, 2015 | 04:21 PM
The cam is no where close to ideal for that setup, that was obviously your blower cam. With that cam and turbo with a stock converter I imagine 1st gear is pretty mild and soft. What rpm does it actually spool at?
Old Dec 25, 2015 | 04:32 PM
GMCtrk's Avatar
You're way down on power. Trap is very low.
60' is separate issue and running that cam and setup with a stock converter???
