6.2 turbo build
Old Jul 5, 2015 | 09:37 AM
  #931
TrickTurbo's Avatar
Truck Sponsor
2) coolers?
Old Jul 5, 2015 | 06:40 PM
  #932
Byrdman11's Avatar
I mounted this cooler under the truck but it wouldn't keep the trans cool. Moved the cooler to the front so it will get air and hopefully keep trans cool.
Old Aug 15, 2015 | 11:57 PM
  #933
sierra416's Avatar
Registered User
Having the same problem. Mounted it low under ATI damper. Still not cooling good despite location. Going to cut out the lower grille to get air flow. Good luck with your bro
Old Aug 16, 2015 | 10:36 AM
  #934
George C....'s Avatar
Formerly ScreamingL
curious why are all the pics so damn small?
Old Aug 20, 2015 | 08:54 PM
  #935
Byrdman11's Avatar
You have to click on them. But I wish I knew how to fix them. Two different computer do the same thing.
Old Aug 20, 2015 | 09:12 PM
  #936
Formerly ScreamingL
fullsize pics would get this thread alot more action
Old Aug 20, 2015 | 09:15 PM
  #937
Byrdman11's Avatar
Guys the truck is back at it. Got transbrake working, and the trans cooler work better in the grill area. The bigger intercooler helped big time with building boost faster. It use to get to 3lb pause a second or two when go up to 5lb. Now I can build boost like straight up until it spins. On the transbrake it is un Damm real. The truck go to building before full throttle now. Transmission mods also includes the vacuum controlled trans pressure. If itruck boosting it full pressure. Nitrous is still to be tested.
Old Aug 20, 2015 | 09:23 PM
  #938
Byrdman11's Avatar
Can you click on the pics and make them bigger?
Old Aug 21, 2015 | 10:45 AM
  #939
slow2008's Avatar
formerly slow03 (11-04-2011)
Yes, but instead of attaching the photos with the attach function on here just upload them to photobucket and use the share feature. They will be full size automatically. Plus you can also upload more than one photo per post as well.
Old Aug 21, 2015 | 11:22 AM
  #940
Byrdman11's Avatar
Thanks I will try that.
