6.2 turbo build
Old Feb 7, 2015 | 08:02 PM
  #771
GMCtrk's Avatar
Depends how much you want to spend.
Hydroboost - $150-200
Transbrake - $600
The transbrake would probably be better ultimately, but the foot brake should be plenty good to hold a significant amount of boost.
Old Feb 7, 2015 | 08:05 PM
  #772
TrickTurbo's Avatar
Truck Sponsor
I think hydro gives you 2 pluses.
Better brakes
Costs less then tbrake
Trans brake.
Locked down. Build what boost you want.
Just do the line lock diode trick to keep your driveline from relaxing.
Old Feb 7, 2015 | 08:56 PM
  #773
Byrdman11's Avatar
Do you know all the parts and maybe part numbers?
Old Feb 7, 2015 | 09:44 PM
  #774
Byrdman11's Avatar
I have a vacuum module at the booster but think i can get around that by leaving the module in place to read vacuum.
Old Feb 7, 2015 | 09:47 PM
  #775
GMCtrk's Avatar
Crazy how the cost just keeps going up and up huh? Takes a lot to get a heavy EC/CC into the low 10s/9s. If your setup was in a cookie cutter foxbody/f-body, you'd already be well into the 9s, likely 8s.
Old Feb 7, 2015 | 09:50 PM
  #776
Byrdman11's Avatar
I still don't know the reason I can foot brake on the street. It take a few seconds and the boost will go up to about 3lb and then spool until I can't holded it. I wish it the weather.
Old Feb 8, 2015 | 12:15 AM
  #777
blownescalade62's Avatar
Nice run Mark! Need better brakes or T-brake.
Old Feb 8, 2015 | 04:14 PM
  #778
Byrdman11's Avatar
I did some logging on the truck today and I can foot brake boost up to 4lb before it spin up the rear tires. Rpm before spinning the tires 3950rpm. Ordered the 2step today. I'm still on the fence about transbrake or hydroboost.
Old Feb 8, 2015 | 08:13 PM
  #779
Oh... I thought you had a 2 step on it! That should help out but I would still do a tbrake on her Mark.
Old Feb 8, 2015 | 08:20 PM
  #780
Byrdman11's Avatar
Blown I looking in some thing now. To get this truck really going.
