6.2 turbo build
Old Nov 10, 2013 | 07:54 PM
  #271
Choda's Avatar
Byrd do u have real tires under it? Or any suspension mods like cal tracs?
Love this truck and can't wait to see it kicking more ***
Old Nov 10, 2013 | 09:01 PM
  #272
Byrdman11's Avatar
I have 305 drag radials on it all the time. Mods to the suspension is
caltrac bars, adjustable shocks, flipkit rear, spindle in the front and
my install the stuts under the control arm to get the truck down and
still have the lift in the front with the stock springs for traction. I also disconnect the swap bar in the front to help with frontend lift that also
help traction. Slicks will be on the truck too after I get the bug worked
out..
Old Nov 10, 2013 | 09:05 PM
  #273
Byrdman11's Avatar
Originally Posted by damianldaigle
What gears and size tire you running?
Gear is 3.42 tires are 305 nitto drag radials 28.8 I think.
Old Nov 10, 2013 | 09:10 PM
  #274
Byrdman11's Avatar
Originally Posted by GONEB4U
If your looking to really lean on the truck then no doubt that a 4L80e is a better choice. I'm actually looking to down grade my cam to a LS9. I'll be happy with whatever it makes at 15 psi.
I would go with the LS9 cam its not back pressure friendly. My cam is so mild it sound almost stock in gear. what turbine is with your turbo??
Old Nov 10, 2013 | 09:48 PM
  #275
11silverado's Avatar
With that much rwhp you will have to go to 4l80 or 6l90 for sure..
I havent seen anyone with over 600rwhp last with their 6l80 / 3200+ stall converter for long. seems to hold in the 500's but over that and problems start. if you get sticky tires the problems should escalate forcing the tranny to really do some work..
i would imagine there is one or two cases out there on the 6l80 but from all the trucks/cars I have seen with 6l80 , unless its built they give up at about 600+
Old Nov 10, 2013 | 10:13 PM
  #276
Byrdman11's Avatar
Just ordered my 4L80 and mult disk converter. Time to start building a crossmember and new cooler lines.
Old Nov 11, 2013 | 09:08 AM
  #277
GONEB4U's Avatar
10 Second Club
I took Tick's advice on a cam spec for my truck and I absolutely hate it. I told him I was thinking of just going with a LS9 cam and he said the same. I told him that I want stock idle and he spec'd me this:
Turbo Silverado - YouTube
It makes great power but its not what I wanted. I know the LS9 is not ideal but it will idle near stock and work fine enough. What cam do you have or recommend?
I have a BW 80/83 t4 1.10.
Old Nov 11, 2013 | 11:32 AM
  #278
Byrdman11's Avatar
My cam in gear is very mild. What's your cam spec card say? post it up.
Old Nov 11, 2013 | 12:14 PM
  #279
GMCtrk's Avatar
Who'd you end up getting the transmission from?
Old Nov 11, 2013 | 01:41 PM
  #280
damianldaigle's Avatar
The GT2-3 has great idle characteristics and has been in 800hp+ builds
