6.2 Procharger questions
Old Mar 11, 2015 | 08:10 PM
Delaware ss's Avatar
Default 6.2 Procharger questions
Sorry if it has been covered I have just read a couple different things and also getting a lot of opinions so want to double check
2011 Silverado 6.2L with a D1 procharger set at 8PSI
Tuner kit with optional Pin Kit and getting dyno tune
Will stock Flex fuel injectors be ok?
MAF OK?(Was told I need a 2 bar MAP)
Anything else I will need?
Thanks
Old Mar 11, 2015 | 08:34 PM
sharpshooter's Avatar
I'm not sure on the injectors but you won't need a 2 bar map. You won't need to go speed density on a 2011. It will be maf tuned.
Old Mar 11, 2015 | 08:44 PM
Thats what I thought but doesn't hurt to check, The injectors are 58LB from what ive been told so pretty sure they will be fine at only 8
Old Mar 11, 2015 | 08:45 PM
George C....'s Avatar
Formerly ScreamingL
6.2 FF are around 52lb so for small power you should be ok
Stock fuel pump will be fine
Old Mar 30, 2015 | 07:39 PM
JCW's Avatar
JCW
I also have same vehicle and was wondering about FF injectors being up to the task...
Old Mar 30, 2015 | 07:42 PM
vettelovralexand's Avatar
I would say you will be right on the limit of the stock injectors depending on how high you spin it.
D1SCSS
Jan 25, 2016 10:14 PM
JCW
Sep 22, 2015 03:59 PM
Three6GMC
Aug 28, 2015 07:56 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
