5.3 single turbo what do i need
Old Oct 19, 2014 | 11:05 AM
Boost-freak's Avatar
You're turbo setup will take about $5000 when it's all said and done. I'd go 4l80e for od and ease of install. You'll blow your budget pretty quick getting crazy on the trans. You shouldn't need anything that crazy for your hp level.
76 mm will support over 800 so you're good there.
Hp tuners pro setup is $700. Which I recommend over the regular due to datalogging. I'd buy all your fuel stuff first so it's out of the way. You'll have a chunk of change into that before it's all said and done. Nothing like wanting to fire it up and you're missing fuel stuff.
yeah i figured it around that , i gave it 6K for my turbo setup without the other stuff
i have to think about which trans , it's not a DD so 50% for both ,
i will update my setup tonight , thanks a lot
Boosteds12 basically said it the way it is. You need 5k to do a turbo build from start to finish. You don't need gears or trans if you respect what you have and don't get boost happy.
x2 he gave me a lot to think about that's for sure .
That budget is extremely tight for 600-800 rwhp.
it can be done if i spend it wisely
Old Oct 19, 2014 | 12:50 PM
TrickTurbo's Avatar
Truck Sponsor
6k for a turbo setup is a nice turbo build.
Old Oct 20, 2014 | 09:43 AM
i decided to go with this :
trick turbo kit stage 2 with borg warner 76mm .
jake's 4l80e .
will update the rest later
Old Oct 20, 2014 | 08:15 PM
TimDave217's Avatar
if your looking for an easy pump that drops in, go with lonnies performance. i told him i wanted to make 800-900 on e85 and he set my pumps up and sent it back with a very reasonable price! never looked back on fuel system since then been 3 years now.
Old Oct 21, 2014 | 08:42 AM
yup it should be , say rick if i buy a stage 2 from you with upgraded IC + a Borg warner 76mm unit how much will it cost me ?
will consider it , i thought about making an external pump .
injectors 95 will do ? or should i change it also ?
i have a 42 fast injectors right now so i don't know about this fuel stuff which will do fine ?
Old Oct 21, 2014 | 09:57 AM
boostedsl2's Avatar
I'd go with 80 lb dekas. Easy to setup in HP tuners and they should support over 800 whp. a single walbro 400 will be enough, otherwise you can ghetto fab/modify the stock pump housing and drop in a couple 255's or 340's.
255's are on the cheap and can support over 1000 whp easy.
Some will argue this, but from what i've been reading, a stock 4l80e with a shift kit in good condition should take 600 whp all day long. 800 seems a little iffy.
make sure to save 500~1000 for last. You'll need it when you bring everything together. Don't forget about gauges, fans, trans cooler, fuel setup fittings/hoses.... those will milk you last second for sure, lol.
Choda
Jan 22, 2026 02:03 PM
Raggedz71
Jul 29, 2016 10:20 AM
Jake99
Aug 8, 2015 07:56 AM
vmaxpro
Aug 4, 2015 07:02 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
